All my personal cars have been manuals. My last two were T56 6 speeds. I have to tell you, the first T56 was a great tranny, smoother than butter, but I don't like the 6 speed in my 01 Z28.
I drove both the manual and auto C6's before I ordered mine and if anything the manual was even worse than my current Camaro's. The other problem is if you drive it hard you will go through a lot of expensive clutches. The best way to launch an LS1/LS2 is to slip the clutch coming out of the hole and the stock clutch doesn't like that at all. If you don't slip the clutch you will spin the tires hard and if you don't spin the tires you bog the engine.
One other consideration, the autos are much easier on the rearend, they will last a lot longer.
In the end, I hate to admit it, but I ordered the A6. I wouldn't have done this if it weren't for the paddles, I want to be able to keep it in the gear I want when I autocross. The only problem with getting the A6 was I couldn't get the car in PINK!!!
I was looking at moving up the the c6 from my 00 coupe.
Ever since my your days (i.e. 4 years ago when I was 20) I promised myself I would never EVER again buy a auto vette. My 88 was auto and it just wasn't as fun. So my question was am I really going to receive any improvement in going from the c6 m6 as opposed to an A6? Is the paddle shifter indy style with great response or is it closer to the crap triptronic stuff? I guess I have to drive one to really know.
I hope that made sense???
Been driving for 47 years, 28 of them as a profession driver, this is my FIRST EVER automatic , I have had 2 other vettes. I love the paddle shifter and no I don't think it's a toy.
sports car
Technologies change. The A6 is just the beginning. And there is more then one mechanical solution to enabling a vehicle to perform well.
Yes technology is certainly getting better. The DSG (Audi V6 TT) is probably the best automatic transmission I've driven, I still prefer to roll my own though.
Thanks,
Glenn
Just a note Glenn, the A6 in sport mode (Paddle shifter) will down shift for you if your speed warrants it, whether or not you want it to.
At a stop you have todown shift to first --if you wish that gear otherwise it's starts in second. In sport mode it will not shift up to 6 th gear unless you are going better then 50.
My opinion is if you are drag racing the A6 use S, the manual (paddle shift) mode can't beat it. S takes you to 6,500 and has a very hard shift to the next gear. Looking at the boards there are some 12.7 times out there and all are with the system in S.
Wow. I never thought of this. You are absolutely right, the A6 has a BIG advantage at the Drag Strip. Leave it in S and it will shift automatically at redline and shift FAST! That would be great for consistency which is so important at the drag strip!
sports car
n.
An automobile equipped for racing, especially an aerodynamically shaped one-passenger or two-passenger vehicle having a low center of gravity and steering and suspension designed for precise control at high speeds.
I do not think that a manual is required to consider a vehicle a "true" sports car.
A Corvette. ANY Corvette is a true Sports Car.
FWIW, the current issue of Corvette Quarterly has an article comparing the M6 to the A6 on a race track and autocross. The M6 did 1:27 on the track with the A6 close behind at 1:27.8. However, the A6 bested the M6 in autocross with a 35.1 vs 35.5.
If you are manually shifting gears you have to be driving pretty poorly for it to downshift for you. If you want to really load your engine and try to accelerate in 4th gear going less than 20 MPH then it won't allow it and downshifts to 3rd, 10 MPH for 2nd. It also prohibits downshifts in any gear if it will overrev the engine. I can't think of any scenario where I wouldn't want it to do that.
Your '88 had around 240 HP on 255/50's? C6's have 400HP on 285/35's. It's gonna be tough to make a comparison there. The '88 is Pontiac Grand Prix GT fast. The C6 Vette is scary fast. Tranny type is gonna be personal preference every time. Don't buy one without trying both.
Thanks for the heads up, I had read where it does downshift to second. However in a slalom I would assume it would downshift quite a while after I already would downshift. If I haven't downshifted because I'm not paying attention, then the car will make up for my incompetence. Doesn't seem fair. Of course, most of the slaloms we run here in Arizona are 1st and 2nd gear slaloms. Most are just 2nd gear with very few shifts back to 1st.
I guess the A6 paddle shifter wins this one...One question though...The A6 in "s" mode WILL AUTOMATICALLY SHIFT UPWARD at 6500 RPM without me pressing the button? Did I read that right?
If I wasn't so distracted by your avatar, I would comment on your lack of a comment.
In the words of Seinfeld: Jerry says to George..."Looking at clevage is looking at the sun, you dont stare at it, you take one look and then look away....
My yore days go back a little farther, but I made myself the same promise after owning a '73 auto, so my '97 and now my '06 have both been manuals. You really should go drive both for yourself, of course, but much has been reported here that I consider reliable info.
The new A6 is a fine transmission, and just as quick or quicker at the track (particularly for the less experienced and/or skilled at shifting) according to several reports which I have no reason to doubt. However, the bottom line for me is that the MN6 is simply MORE FUN to drive. I am not alone--others here have tested both extensively and report the same on the "fun to drive" meter. The A6 is a great option for those who don't like or want or can't shift a manual, but it is just not as much fun to drive as a MN6 for those of us who like to shift our sports cars.
This thread was posted in the Tech section where someone ran 12.48@112.11 in the 1/4mi....in a bone stock A6
