Passenger Window Problem...
Old Apr 5, 2006 | 09:56 PM
GreggHammer's Avatar
GreggHammer
Default Passenger Window Problem...
Has anyone experienced a problem with their windows going up and down as if it’s not indexing right? My passenger side goes up and down about 10-15 times before finally setting itself right. I'm dropping it off at the dealer on Monday but I want to have some background on the problem before I try to describe the issue.
Old Apr 5, 2006 | 10:00 PM
Vette_DD's Avatar
Vette_DD
Window indexing improperly has produced several symptoms. Try resetting the window indexing by raising the window and holding the up switch an extra 3 seconds after the window finally closes. Release the switch. Hold again in the up position (without lowering the window) for 3 seconds. Release. See if that fixes your problem. If not, you'll probably need to take it to the dealer.
Old Apr 5, 2006 | 10:27 PM
GreggHammer
I reset the window using the instuctions you gave and it seems to have taken care of the problem for now... I'll keep an eye on it over the next few days and see if it stays fixed. Thank you for your help.
Old Apr 6, 2006 | 06:39 PM
GreggHammer
The window gremlin is back! It sounds like there is a relay or something that you can actually hear clicking and I think that’s what the problem is, a bad relay. Too bad our local dealer probably doesn't stock the relays and it'll have to be ordered. I have an appointment Monday, so I'll see what happens.
Old Apr 13, 2006 | 01:42 AM
GreggHammer
Faulty passenger window switch. There was even a trouble code in the computer. Apparently most (or all) of the electrical system is monitored by the computer. On the downside, the switch is on backorder so I'll be a few more days with a malfunctioning window!
Old Apr 13, 2006 | 09:40 AM
caw0917's Avatar
caw0917
I noticed yesterday upon shutting down that the passenger window was not down all the way... stuck out of door about 1/2 inch. Ran it back up, and held the switch up for 10 seconds or so, for three times (couldn't remember the procedure, figured that would get it). Problem fixed for now. We'll see if it reappears.
Old Apr 14, 2006 | 01:55 AM
GreggHammer
In my case, they determined that there was corrosion on the inside of the switch, causing an active signal when the switch isn't pressed. FYI: the DTC for this problem is B1474.
Old Apr 14, 2006 | 10:57 AM
hog driver's Avatar
hog driver
Thanks for the info on the code.
Old Apr 19, 2006 | 02:16 AM
GreggHammer
All fixed: 7 day wait for the part, 30 minute fix by the tech.
Part #10446243. It's nice to have a completely functional automobile!!!
To Passenger Window Problem...
