check gas cap code???
Old Apr 9, 2006 | 05:31 PM
tom p's Avatar
tom p
Default check gas cap code???
anyone know what this is about.I know my cap is tight and before i go to the dealer i was wondering if anyone has a similiar issue ??? I started with a half a tank., and won't go away. Thanks for any help.
Old Apr 9, 2006 | 05:34 PM
jnx911's Avatar
jnx911
Sometimes it will reset itself. How many cycles have you been through since you corrected the problem?
Old Apr 9, 2006 | 06:44 PM
lexaudio's Avatar
lexaudio
Someone here mentioned they had this problem and GM sent them a new gas cap.
Then it went away.
LEX
Old Apr 9, 2006 | 07:42 PM
benspruce's Avatar
benspruce
I had this code appear on two different occasions. Other forum members suggested that when I replace the gas cap after filling up to place it gently on the fill hole (do not try to force it on or use pressure - easy does it) and make sure the cap clicks 3 times. I have been doing that with success ever since. The forum saved me an unnecessary trip to the dealer. Thanks again
Old Apr 9, 2006 | 08:18 PM
It'sHerVette!'s Avatar
It'sHerVette!
St. Jude 15 Year Donor
St. Jude Donor '07 thru '25
Never had a problem. But we in NJ have highly skilled gasologists direct from an assortment of third world countries who pump our gas for us and carefully replace the gas cap!
Old Apr 9, 2006 | 08:20 PM
Lightning Coyote's Avatar
Lightning Coyote
Way to go CF members
Old Apr 9, 2006 | 08:59 PM
PappyTinker's Avatar
PappyTinker
From: Life ain't no dress rehearsal, are you gonna wait to get your toys til AFTER you have a heart attack?
Hey, come on. Give 'em a break. They are computer programmers who were laid off by AT&T there.
Old Apr 9, 2006 | 11:29 PM
rm50's Avatar
rm50
2020 C8 of the Year Finalist - Unmodified
Old Apr 10, 2006 | 02:24 PM
carjon's Avatar
carjon
Had this code "continually" and it turned out not to be gas cap problem but a broken pipe that links the 2 gas tanks. A vapor leak anywhere in the system apparently triggers the same code. Took a "clever" service department with "smoke generating leak finding" equipment to determine the source of the vapor leak and then they could fix it.
To check gas cap code???
