"headers in calif."
Old Apr 15, 2006 | 12:57 AM
Pontiaker's Avatar
Pontiaker
Originally Posted by midnite902
Callaway and B&B have C.A.R.B. certified headers. B&B use a "snake pit" design with 22" primary tubes and a short collector feeding the stock CATs.
Some of these shorty headers have actually shown a loss on the dyno on LS1 cars, not sure about LS2 but Iam guessing it would be the same.Just not worth the time or money in my opinion even if you get the 8 hp some of the makers claim.
Old Apr 15, 2006 | 01:01 AM
benspruce's Avatar
benspruce
Originally Posted by ricatthebeach
I believe you are reading the law correctly. However, there are plenty of smog places that only care if the car passes the "sniff" test, and look the other way when it comes to headers.
When I had my LG longtube headers installed the shop told me there are numerous smog places where all they care about is the sniff test. Find a smog guy with very thick glasses. And as was said earlier a lot of smog guys really don't know what to look for. I live in California and I'm not losing any sleep over my mods.
Old Apr 15, 2006 | 01:15 AM
JohnDS's Avatar
JohnDS
Originally Posted by 1bdasvt
Hey John,I've heard from some people that it's 6 years?And do you live in calif?
Sorry, I do, and I know it is 4 years grace from my last 2 cars.
John
Old Apr 15, 2006 | 01:49 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
hey midnite,I called B+B this morning and they do not have c.a.r.b. approved headers!
Old Apr 15, 2006 | 02:07 PM
emejay's Avatar
emejay
I assume the only way one would know if long tube lheaders were installed would be to look under the car, and I have NEVER had a smog tech look under any car I have had smogged, especially a Vette which would require lifting the car to see underneath.
Is it true that long tube headers appear similar to stock when viewed from the ltop of the engine?
Old Apr 15, 2006 | 02:11 PM
shopdog's Avatar
shopdog
No. Individual tube steel headers bear very little resemblence to the stock cast iron manifolds. They're very obvious to even the casual observer looking under the hood.
Old Apr 15, 2006 | 02:17 PM
emejay's Avatar
emejay
How about for a Z06? The C6Z06 I saw looked like headers as I saw no cast iron manifold. Does the Z06 come from the factory with a cast iron manifold? Thanks for the feedback.
Old Apr 15, 2006 | 04:35 PM
shopdog's Avatar
shopdog
Yes, the Z06 LS7 uses a cast iron manifold. But it is very different from the manifold used on the LS2. It has separate (short) runners, a very fat and short collector, and there is no downpipe. The (special) cats mount directly to it. Definitely a unique looking piece.
Old Apr 15, 2006 | 04:50 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
How headers look:
Old Apr 15, 2006 | 05:04 PM
jrjen2's Avatar
jrjen2
I live in Alaska and we have smog testing too. The testers here go pretty much along the lines of California laws. I know that th testers here would pop my hood, see the headers, ask for my CARB paperwork, I would grumble and scuff my feet, and then they would fail me on a visual inspection. The inspection station would never even hook me up to the machine. Just this year, Alaska went to the first four years of vehicle ownership are free from testing. Up until last year, it was the first two years.
I have a set of B&B headers on and I am not worried about our testing. Here is the kicker. In AK we have a seasonal waiver in that the registration is cheaper but you cannot drive the vehicle between 31 October and 1 April. The good thing is that no emssions test is required. I doubt many southern states have anything like a seasonal waiver because you guys don't have snow from October to April either.
I'd imagine that if you live in California, and you want headers than plan on putting the stock manifolds back on every time inspection rolls around.
Old Apr 15, 2006 | 05:47 PM
Pontiaker's Avatar
Pontiaker
John
Well your wrong, you get a pass on the first two smog checks which you can call four years if you like but you dont have to smog the car until the third smog check would be due which is 6 YEARS from the year model of the car. Hence my 2005 does not need to be smogged until 2011, as stated by DMV last week, and I did NOT have to smog it for transfer of title. I just paid the fee's on my 2002 Trailblazer and still no smog due for that car either, not until 2008.
Old Apr 15, 2006 | 06:03 PM
shopdog's Avatar
shopdog
Here in Georgia, for an OBDII car (anything made after 1996), they just plug you in and read the ECM for fault codes. No fault codes, you pass. Simple, quick, $25. Older cars still have to go on the dyno and sniffer because their self-diagnostics aren't complete enough. The visual inspection consists of flipping open the fuel door and seeing if you have the OEM filler cap.
Old Apr 15, 2006 | 10:53 PM
  #33
bunk22's Avatar
bunk22
My C6 is registered in CA and has long-tubes. Like Cucchiara said, it is 6 years. I'm moving to Florida this summer so I will register there anyway. No worries..........knock on wood.
