Break in...
The thing is I am trying to hit the 1/4 next weekend, how many miles should I wait before I hit the track?
The thing is I am trying to hit the 1/4 next weekend, how many miles should I wait before I hit the track?If the track is a drag race track I suggest 1500 miles of 'typical' driving
But, if you spend this weekend on a long back country road with very little traffic and low levels of constabulatory oversight, migrating the engine RPMs from 2000 to 6000 to 2000 to 6000 in 8* second intervals 2000->6000 in 8 seconds (2nd or 3rd gear) 6000->2000 in 8 seconds. Just go up and down the RPM band, you can shave 500-700 miles off my above suggestions.
[*] in 2nd gear this will be closer to 6 seconds up and 6 seconds down with the suggested light throttle openings. In 3rd gear it will be closer to 8 seconds up and down.
This loads up the engine just enough to seat the rings, and then enables the vacuum in the cylinders to pull some oil up the ring pack for top cylinder lubrication. It also applies changing and moderate loads in the driveline to break in the gears, bearings, and CV joints.
After an hour of this, you can start to run up and down the RPM band faster and faster. And by the end of the day, the engine and driveline will be well broken in.
Of course someone will tell you he flogged it from day one and has no problems, but who knows if his engine & driveline would have been even better with a proper breakin.
Wish I knew this leaving the dealership before I hit the long freeway drive. Since then I am strictly by the book.
For me that kind of driving was fun, not a screw job.
The thing is I am trying to hit the 1/4 next weekend, how many miles should I wait before I hit the track?And as others have indicated, varying the rpms/speed is the also a correct thing to do.
We just mapped out a course that mixed a few miles on the "back roads", a few "interstate miles" (mostly around Nashville..55mph speed limit), a few "through town" miles (for the stop and go routine). We were about 175 miles from NCM (all Interstate) and ended up driving 185 back home.(some full auto, some paddle shifting
I'm sure that will go down after the break in is over.
Indeed it’s all about rpm on the engine. Rpm can vary drastically depending on which gear you are in and has little relationship to mph speed.
