Replace caliper bracket bolts?
Old Apr 15, 2006 | 04:42 PM
vettnutt's Avatar
vettnutt
Default Replace caliper bracket bolts?
The service manual says to replace the caliper bracket bolts if you remove them or they become loose. Anyone know why? Wouldn't lock tight work to secure them? Anyone not replace (use the old ones) them after removing them? Problems? Thanks...
Old Apr 15, 2006 | 04:53 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
They say that it reduces the strength of the bolt and it may fail. Most of us just reuse them.
Old Apr 15, 2006 | 05:03 PM
9t6t7's Avatar
9t6t7
A little bit of lock tight on the bolts before you put them back..............
Old Apr 15, 2006 | 05:04 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
No need to replacethem !
unless you have 120,000 miles on them !
Old Apr 15, 2006 | 05:15 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
The bolts come pre-impregnated with a type of thread locker on them. It wears off when you loosen them or remove them.
That being said, I have reused them several times with no problems. You don't need more thread locker, but it couldn't hurt, either.
To Replace caliper bracket bolts?
