When does MPG STOP getting better?
1) What was your difference between the DIC and your manual calculations?
2) Calculating your mileage to 5 significant figures? Just how accurate do you think your various gas pump meters are? I'm sure that there are laws that regulate their accuracy, but I'd bet there's more than a 1% variation there.
Gas pump meters have to be very close. Each state has a different agency that checks the accuracy of the pumps every year or so (some states may vary). I used to help my grandfather measure the pump accuracy when I was younger. He was the inspector of weights and measures for W. Springfield Mass. You take a 5 gallon measuring container with a meter on the top. You fill it up with the pump on the slow setting and once on the fast setting. If it is within a specific accuracy, the pump gets a seal with the date stamped on it. The seal cannot be broken or the station gets in big trouble. That way, it keeps stations from modifying the pumps to overcharge.
Next time you are filling up, look for the decal on the pump and it should tell you when the last time it was verified.
1) Do you remember the variance allowed?
2) When will they get rid of the damn .9?
When gas was 17.9, I could almost see it. But 3.00.9? It's less than 1/3 of a %!
But that said, your accuracy in always refilling the tank to the exact same level isn't anywhere near that close. Nor is your odometer that accurate. I make it a practice to round all MPG calculations to the nearest tenth MPG, and even that may be a bit optimistic. BTW my long term manual calcuations tend to track closely with the long term DIC reading.
C6 mileage is great! C5 ain't bad, either...
