Trunk close Question.....
Old Apr 17, 2006 | 12:47 AM
lexaudio's Avatar
lexaudio
Default Trunk close Question.....
Sometime when I close the trunk it just is closed.
It doesn't do the "slam, then power close".
Is there something wrong, or is it because I left the car with the FOB and it lock shutting off the system?
LEX
Old Apr 17, 2006 | 12:49 AM
sallen619's Avatar
sallen619
Were your windows down?
Old Apr 17, 2006 | 12:51 AM
lexaudio's Avatar
lexaudio
I don;t know. Maybe.
Could have been. I have been all over town today.
When I had the Top off, the windows were down when I went into the trunk.
LEX
Old Apr 17, 2006 | 12:58 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
LEX
GM installed "softer" rubber seals at the C-5/C-6 bash last year for owner who complained about this
Old Apr 17, 2006 | 01:08 AM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
When the windows are up and top on, the air pressure inside the car puts resistance on the rear hatch when closing...the power pull-down then pulls it the rest of the way closed.
When the top is off and/or windows down, the same amount of force will cause the hatch to latch immediately because the air pressure has not hindered its motion.
Old Apr 17, 2006 | 01:14 AM
lexaudio's Avatar
lexaudio
thanks good to know.
I'll check again, but I can swear that last night everything was up and it did it to me after the 8 second FOB leaving the car.
I'll try again. I am going to wash the windows for tomorrows drive to work.
Damn car. I can't keep msyself away from it.
GF jealous. Sexier competion. L
LEX
Old Apr 17, 2006 | 01:30 AM
6th Gear's Avatar
6th Gear
Hey LEX i know exactl what you are sayin... Sometimes the trunk won't pull down by itself... and ill push acouple of times and then ill lift it back up and try again and it will work... i guess they just act up sometimes...
Old Apr 17, 2006 | 01:36 AM
lexaudio's Avatar
lexaudio
My 350Z was like that but opposite.
I would unlock the trunk and have to unlock it again to open it.
I don't like things to act up. Going back to dealer for explaination.
That way, they have record of the complaint. I helps when you are trying to get something done in the future.
They will look at the # of times you have complained about it, and not call it wear and tear.
IT helped with my Z windows.
I liked the Z, but I LOVE this car.
LEX
Old Apr 17, 2006 | 02:10 AM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
I've never had this happen. If mine doesn't close fully on the first try, gentle pressure over the latch and the pull-down takes care of it every time. Sounds like you may have a problem.
Old Apr 17, 2006 | 02:13 AM
lexaudio's Avatar
lexaudio
Well, I went down.
Window up, it did like it should. Just need to slam it down a little harder.
LEX
Old Apr 17, 2006 | 05:07 AM
lagogarda's Avatar
lagogarda
St. Jude Donor 06
No problem...if windows are up, you will have to press down in the middle of the hatch to engage the power pull-down, if windows are down, it should engage itself.
Old Apr 17, 2006 | 06:19 AM
jdavis's Avatar
jdavis
I never have to slam mine with the windows closed. I just lower it all the way down and then apply slight downward preasure to the outside center with my hand. It sucks it right down. If yours isn't operating the same, you do have a problem. You should never have to "slam" the hatch down.
Old Apr 17, 2006 | 10:51 AM
BigJoe's Avatar
BigJoe
Well said!
Old Apr 17, 2006 | 11:25 AM
noreserve's Avatar
noreserve
I just don't get GM's "fix" for the C5/C6 hatch closing problem. Yes, it's a problem if it doesn't close with a reasonable shut. It's also a problem if the "fix" of using a motorized pull-down requires you to push down with your palm on the hatch to engage it. Where's the logic here? Why didn't they design it so that you just have to simply close the hatch with hardly any pressure and then the motorized pull-down could grab the latch without you having to press on the *&@$# thing. Yes, my hatch closes with no problem if there are doors/windows open/down. That is not usually the case though that I leave a door open and go to the rear of the car, only to have to go back and close the door or window.
Why didn't GM index the side windows when you press the interior hatch release or fob so that the hatch can then be closed easily? As soon as the hatch is closed, the windows would inch back up. It should be easy enough to do. The electronics know whether the hatch is open or closed because you get that message on the DIC if it's open. I talked to Top Down Tech about them adding that feature (indexing on hatch open) in their Window Valet, but the guy didn't seem to think there is a problem since GM had implemented the motorized pull-down. I told him that the "fix" doesn't work like most envisioned it would. I also told him that I bet he could sell hundreds of the Window Valets if he added that feature. Oh, and what's with that plastic close handle on the hatch? That has to be the cheapest component on the whole car!
Old Apr 17, 2006 | 11:29 AM
anothercrisis's Avatar
anothercrisis
St. Jude Donor '06-'07-'08
I have noticed that a quick trip into the trunk with throw off the automatic pull down...in other words, the latch doesn't seem to have time to reset. You can hear this if you stand at the rear of the car and open the hatch, waiting a few seconds you can hear the mechanism "reset"....at least on my car. If I close the hatch too quickly the pull down doesn't seem to be engaged...
anothercrisis
Old Apr 17, 2006 | 02:39 PM
double eagle's Avatar
double eagle
I lower mine by hand until it rests on the latch, then close with my elbow - don't like slamming anything...
Old Apr 17, 2006 | 03:54 PM
mbonness's Avatar
mbonness
My wife really hates the way the hatch operation works, so I usually close it for her. It seems like it takes more force to engage the pulldown than in other luxury vehicles, i.e. my wife has to lean down on it with half her arm to get it to close.
I find it much more satisfying the way it closes with the hardtop removed, it just slams all the way down...
Old Apr 18, 2006 | 01:53 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
double eagle-
Be careful, you could come down the dreaded "Corvette Elbow".
Old Apr 18, 2006 | 03:08 PM
double eagle
Yep, I'm being really careful
To Trunk close Question.....
