Lug Nut Socket
Old Apr 20, 2006 | 05:42 PM
MWAZ's Avatar
MWAZ
Default Lug Nut Socket
I want to buy a 3/4 (19mm) non-marking socket to use on the lug nuts on my new ride (will pick up from NCM June 1st!). So my question is: will a standard thickness deep socket clear the wheel around the nuts or do I need a thin wall socket?
ProTec Tools made a fiberglass insert socket but seems to be no longer in business. I've found a high quality aluminum insert socket from Torque Stick that looks good but it has the standard wall thickness. http://torquestick.com/cart/customer/home.php?cat=40
Old Apr 20, 2006 | 06:26 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
My Craftsman 19 mm socket is standard thickness and works OK, but there are probably variations between different manufacturers. Heck, there are probably 5 different companies making sockets for Sears!
Old Apr 20, 2006 | 06:28 PM
Zuntov's Avatar
Zuntov
Mid America Motorworks has a plastic lined lug nut socket..
Old Apr 20, 2006 | 06:56 PM
MWAZ's Avatar
MWAZ
I've found this same socket elesewhere and it says "for aluminum nuts ONLY" (Porsche).
Old Apr 20, 2006 | 07:34 PM
oak3x's Avatar
oak3x
Just ordered mine from Mid America
http://www.madvet.com/shop?frame=1.5650
Old Apr 20, 2006 | 08:25 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Thirty Freakin' Bucks!!!!...For ONE dam socket??!!...Dayum!!!!
Old Apr 20, 2006 | 08:37 PM
oak3x's Avatar
oak3x
You own a $50,000.00 + Corvette and you're worried about a $30 socket which will keep your lugs looking new.
Old Apr 20, 2006 | 08:41 PM
xs650's Avatar
xs650
I expect someone who paid $150k for a $50k Corvette wouldn't object to a $30 socket, but a person who paid $46k for a $50k Corvette just might be interested in value per dollar.
Old Apr 20, 2006 | 08:52 PM
bigearl56's Avatar
bigearl56
Default Socket get the Socket!
Got mine from Mid-America. Yea it was 30 bucks but I have used it two times to take the wheels off. It does not, I repeat, not scratch or mar the lugs in any way. It is actually a 22MM socket sleved down to 19MM. Hope this helps.
Old Apr 20, 2006 | 09:19 PM
JmpnJckFlsh
What I'm objecting to is the Corvette tax on a $5 socket. Your willingness to pay it is your decision. (Actually, my Corvette was closer to $60K than $50K.)
Believe or not, a $30 nylon-lined socket is not required to keep your lug nuts looking new...it WILL allow you work quickly and carelessly without damage. I have used a standard deep, six-point socket for years with no damage. Believe me, if there were any nicks, scratches, or other marks, I would see them, be pissed at myself, and spring for a $30 socket.
Old Apr 20, 2006 | 09:39 PM
C7GrandSport's Avatar
C7GrandSport
I have this and it works fine.
Old Apr 20, 2006 | 09:47 PM
SA HEAT's Avatar
SA HEAT
Me too. They go off and on with a standard 19mm and 1/2" driver by hand and then get torqued at 100 ft/pounds. I've never nicked or scratched one. Are some guys using impact wrenches on them to get damage? It seems like you'd have to work at it to mess them up using hand tools.
Old Apr 20, 2006 | 10:05 PM
bigearl56's Avatar
bigearl56
Default Thirty Dollar Socket
JmpnJckFlsh, You are absolutly correct a quality six point will work well if you are careful and take your time. So why did I spring for 30 bucks? I know the time will come when I have to report to my "less than careful" tire store. I have puchased and installed several sets of chrome and polished wheels over the years and they all tried to use an impact tool until I went BALLASTIC! . I keep the tool along with a set of pucks in the back just in case. I figured it was a cheap insurance policy I could use. Maybe--just maybe-- it will keep wheel and body damage to a minimum .
Old Apr 20, 2006 | 10:12 PM
SA HEAT's Avatar
SA HEAT
Good point. I wasn't thinking about the gorillas at the tire shop.
Old Apr 20, 2006 | 10:23 PM
oak3x's Avatar
oak3x
I'll buy tour reasoning and explanation. Additionally, I'm sure you're as careful with your Corvette as I am.
Admittingly so, when it comes to purchasing something for my Corvette...sometimes I'm a little of the top ($30 socket, $330 floor jack etc...)
To Lug Nut Socket
