Rotor balance?
Put on a new set of Baer Eradispeed rotors today and now I have vibration from 45-60. Can a rotor be out of balance? Nothing else has changed except for the rotors.
Possible but unlikely. Are you sure a tire weight didn't fall off? One way to find out would be to replace one rotor at a time with an old one until the vibration goes away. Start with the front.
BTW, MCR Corvettes here in Las Vegas did a fine job...very knowledgable and a great father and son team.
Originally Posted by corvette pilot
I'm not familiar with them, are they a 2 piece rotor bolted together? I've always read that those types of assemblies should be turned before installation.
But.......check out the new calipers! I wonder who powdercoated them for me??? Awesome work, dude!! Starlight Red! Oh yeah!!
No...they are 1 piece.
I'm liking your wheels/tires. Can you enlighten me?
Bone
Originally Posted by MAJ Z06
Are the lug nuts tightened properly, clean lug threads, correct torque, correct sequence, back of the wheel clean, hub clean also?
When I recieved my 2 piece rotors and installed them they would make a high pitch noise like a mouse. My dealer was the one that installed them and told me they put it on a machine that said the rotor was warped. I called Baer and they sent me a new one and it worked fine.
Is the vibration under braking at that speed or just cruising? A warped or out of round rotor will not make the car vibrate unless it is under braking. Possibly the rotor hat is not perfectly flat against the hub causing a slight wobble to the wheel/tire assembly.
The vibration is only while cruising....under braking they feel fine.
Originally Posted by mvcrash
Did ya change the pads too?
