Door separating from hinge
Old Apr 27, 2006 | 08:51 AM
whferguson's Avatar
whferguson
Default Door separating from hinge
Took the NEW c-6 in for routine service.
Asked to check out noise when closing driver door. Figure it needed lube.
The door hinge was separating from the door and has pulled through the material. I now need a new door.
Any others having this issue?
Old Apr 27, 2006 | 08:59 AM
StanNH's Avatar
StanNH
That's a new one on me. I don't think I've ever seen a reference to this before.
You now have the honor of coining a new acronym....DHS...Detaching Hinge Syndrome?
Old Apr 27, 2006 | 09:40 AM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Stan, I never get tired of looking at the picture. It is one of the reasons I ordered Machine Silver with the red interior (but a convertible).
Old Apr 27, 2006 | 09:52 AM
double eagle's Avatar
double eagle
Hope it is resolved soon
Old Apr 27, 2006 | 09:55 AM
vette-oholic's Avatar
vette-oholic
Any pics of this ?
Old Apr 27, 2006 | 10:17 AM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Pics would be good. Corvette doors are generally steel with a outer fiberglass door skin bonded to the steel frame. The hinges are bolted to the steel frame so they can be replaced or repaired. Delaminated?! Tore a hole in the door skin? Something is messed up right here.
Old Apr 27, 2006 | 10:22 AM
STPH8N's Avatar
STPH8N
Same thing is happening to me everytime I open my drivers door. I hear like this metal on metal grinding. Everytime the dealer would lube it up it would go away water would have the same effect as well and make it go away.
Old Apr 27, 2006 | 11:09 AM
StanNH's Avatar
StanNH
Thank you! I still love this color combination and would order it again in a second. Next one might be a vert though...coupe is really good, but I do miss that total top down feeling.
Old Apr 27, 2006 | 11:12 AM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05 thru '11,'19,'22,'25
St. Jude/CI Name Tag Designer
Ruh Roh, I better check mine. It's been making a new noise in the last 2 months.
Old Apr 27, 2006 | 11:13 AM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Originally Posted by vette-oholic
Any pics of this ?
Please, please say you have pics.
Old Apr 27, 2006 | 04:15 PM
whferguson's Avatar
whferguson
pics on the way.
1. open door, see if it drops
2. check strike plate for notch caused by dropping door.
3. open door, look behind lower hinge, between hinge outside, along the right angle bend. Hinge base has a steel sandwich, bolted thru the glass. Crack occurs to the outside of this. It should be visible.
If you pull out the speaker, you can feel the door structure bending.
4. A solution before the cracking occurs is to install a strap to keep pressure off of hinge.
Trip
Old Apr 27, 2006 | 05:42 PM
Rocketman50's Avatar
Rocketman50
And just think...you could cruise top down both weeks of summer...
Old Apr 28, 2006 | 08:39 AM
whferguson's Avatar
whferguson
dont know how.
t
Old Apr 28, 2006 | 09:01 AM
whferguson's Avatar
whferguson
Default See crack in glass
C:\Documents and Settings\tferguson\Desktop\BustedHinge.p df
Old Apr 28, 2006 | 10:01 AM
masihman's Avatar
masihman
That link is on your desktop. We can't get to that.
Old Apr 28, 2006 | 10:08 AM
VetteTech81's Avatar
VetteTech81
thats funny..
Old Apr 28, 2006 | 10:15 AM
fts's Avatar
fts
Let us know what the cause is and how it works out.
To Door separating from hinge
