In the delivery bays, are these cars only for NCM pick-up option. If I am not getting NCM delivery, and it's being trucked to local dealer, can I see my car there, or anywhere else on any of their web cams? Building 5/1 and (should be) built 5/2-tues. thanks
Sorry to give you the news - but the only cars to make it into the NCM and seen on their webcams are ones they've prepped for R8C delivery @ the NCM.
If you haven't elected that option, yours will go thru QC in the plant then to a lot out behind the plant for storage until a truck load is routed to your area. It is typically 2 weeks between final assembly and load out of the Allied Transportation carrier to your dealership.
If you're lucky and watch the NCM's website cameras periodically, you can find one with same colors and options... No-one but you will know.
