Dynapad Part Two
I went one step further. Seats are out and at the trim shop. You can really see that the C6 has little or no insulation or sound deadning material in the passenger compartment. It's basically small foam pads attached to the carpet against sheet metal.
The area behind the seats may be the cause of the majority of noise, be it road or exhaust that enters the passenger compartment. Could act almost like a drum. It is a very thin sheet metal, that buckles if you push against it. No factory insulation between the carpet and sheet metal.
Dynapad was installed over the rear area, console and ledge area between the passenger compartment and the Exotic Vette divider.
One roll covers all these areas with little or no leftover or waste.
Factory carpet reinstalled along with the console.
Will not know the results for about a week, but I will post how effective is the Dynapad install in the passenger compartment.
Total cost of material to do the Passenger compartment and the cargo area ( as per BigJag) is about $220.00 delivered for two 32" x 54" Dynapad rolls. Material is multi layer 3/8" thick and weighs 1lb/sq ft. so you are adding about 24-30lbs to the car.
Get yourself a set of service manuals (2 volumes)...they are full of useful info.
I have a "Crazy Cowboy' divider, so I installed the Dynapad on top of the cargo compartment carpet and covered it with the divider rug flap. The 32" of the Dynapad is cut 20" for the rear coverage and the remaining 12" fits perfectly in the cargo are in front of the divider. I cut two large pieces for the rear coverage as it is easier to handle. You will have to make a few relief cuts to contour it to the driveline hump. The center between the two large pieces was filled with a small piece of scrap. I used duct tape to cover the joints, but the material is heavy enough to lay flat by itself.
The rear cargo compartment is your idea and very simple. Because I have the divider, I ordered a vert rear mat. I'll do what you did and use it as a template.
The rear area behind the seats is very thin sheet metal, it actually buckles if you lean against it and then pops back into place. I'm amazed how little or no insulation is in the passenger compartment.
I would think that this area could be a main source of road and exhaust noise.
Probably won't get my seats back until this weekend. I've got an A6 with the original GHL C6 generic version. The A6 seems to keep out of the drone RPM range in fifth and sixth gear. I'm curious to see the effect. If you noticed a reduction, then I should see at least that and hopefully more.
It's a nice product, easy to work with and I thank you for your original post
