Touch-Up Paint - Machine Silver
Old May 20, 2006 | 02:11 PM
oak3x's Avatar
oak3x
Originally Posted by Zuntov
I ordered the "Tarnished Machine Silver" paint from Paint Scratch and It is darker than the GM #67.
Paint Scratch included a sample paint swatch and I dabbed the Paint Scratch color on and the #67 on the swatch.
The #67 matched perfectly. The Paint Scratch is darker.
Guess I'll work a bit more on making that #67 match better on my scratch.
My findings exactly! After a good amount of testing / sampling of both the PAINT SCRATCH MACHINE SILVER and the GM MACHINE SILVER (Code 67), I found the Paint Scratch to be visably darker. Additionally, when you apply the Paint Scratch Clear Coat layer it darkens even more.
Products I used for testing:
Several small pieces of fiberglass ( was lucky enough to find)
Paint Scratch Primer
Paint Scratch Basecoat (touch-up)
Paint Scratch Clearcoat
GM Touch-Up (code 67)
Griots Garage Touch-Up Paint Applicators (excellent product, highly recommended!)
Langka Paint Sealant
Optimum Compound
Some interesting findings from test samples:
PS Primer - Isn't really necessary. With two sample pieces of fiberglass, one I applied touch-up paint directly and the other I used the PS Primer underneath. The application w/out using the Primer adhered just as well...probably better in fact. Furthermore, after drying, the sample with the primed base was easier to scratch off with my finger nail. The direct application touch up was not.
PS Clear Coat - Darkened the already darker Machine Silver even more.
GM Touch-Up (67) - mixed easier, upon shaking bottle...thus allowing a more even application. The GM Touch-Up is a thinner consistancy (than PS), so several light layers is necessary.
Langka Paint Sealant - worked nicely after paint dried. Didn't change the base color touch up paint at all. After Langka Paint Sealant, I polished samples with Optimum Compound
Old May 20, 2006 | 02:18 PM
Dan Seagate's Avatar
Dan Seagate
Default Machine Silver
I have a small chip on the front cowling and this advise will be very helpful, thanks again.
Old May 20, 2006 | 02:47 PM
oak3x's Avatar
oak3x
My pleasure. Two great products from Griots Garage:
Touch-Up Paint Applicators - Makes touch-up very easy, allowing great control to just fill in the chip area. Comes in two sizes, Red Applicator (larger size) and Black Applicator (small size)
Spot Sanding Tool - Allows you to clean the chip area, prior to touch-up.
http://www.griotsgarage.com/search.j...nt+applicators
Old Jan 27, 2024 | 03:55 PM
IDRIVEAC6's Avatar
IDRIVEAC6
Cruising
Default Spectral Paints
Originally Posted by oak3x
Does anyone have experience with the GM Touch-Up paint (code 67) on Machine Silver? How does it blend with the metallic?
I used this paint from Spectral. Comes with the paint and clear coat.
https://www.ebay.com/itm/35383485322...mis&media=COPY
it looks really close on a piece of metal next to the car and it isn’t dry yet.
Still wet but very close for touch up work.
Old Jan 27, 2024 | 04:44 PM
88redconvert's Avatar
88redconvert
I have Langka as well. Waiting for touch-up from Mid America.
My situation: NJ doesn't allow consumers to pump their own gas. Upon getting gas at a station, I found a nice chip by the gas door. Attendent must of hit the paint with the pump / nozzle.
That's interesting (NJ not allowing you to pump your own gas). I didn't know that. I'm in Texas and I can't think of a single place in town that does pump it for you.
Old Jan 27, 2024 | 05:14 PM
R&L's C6's Avatar
R&L's C6
You are responding to a thread that's practically 20 years old.....
Old Jan 27, 2024 | 05:37 PM
FatsWaller's Avatar
FatsWaller
Yah, but is it dry yet?
Old Jan 27, 2024 | 06:00 PM
Vette_DD's Avatar
Vette_DD
Only been a law in NJ since 1949.
Responding to an OP who hasn't been here in 8 years.
Old Jan 28, 2024 | 01:47 AM
Closed.
