Dbs 2006 A6
http://forums.corvetteforum.com/poll...pollid=1500606
'DBS' refers to dead batteries in '05 MN6 cars, which failed despite being properly shutdown in reverse, as required.
Or did they try and charge it up and then test it?
It's way easier for the dealer to switch out the 'offending' part without really testing it or looking into the problem. It also pays better, I hear.
At least you're running now, but you may still be at square one....
If your car had been an '05 manual, "some people" here would be screaming from the rootops about another case of '05 manual "DBS."
Your example is yet another reason why I don't buy into the "'05 manual DBS" hype.
There are certainly numerous instances of bad Delco batteries showing up in cars, but there's more to it than just that. The fact that the vast majority of drained batteries turned up in 2005 MN6 cars, and not the autos, indicates that more than just the battery is involved. You may or may not "buy into the hype", but you're still running a battery tender and Priority Start on your own 2005 MN6. Try disconnecting the electronic life line sometime and see what happens. You may wind up with the same reaction I had when mine went dead after 13 months of normal use....I believe my reaction was "WTF?".
I am talking about the attitude that any and every dead battery in an '05 manual is automatically "DBS", but the same dead battery occurence in any other car is not "and by definition" cannot be DBS.
And statements to the effect that any and everyone who has switched batteries and then gone on to have no further issues "has just been lucky."
Thats what I mean when I say "hype".
There is also the issue of the shift into reverse requirement or wind up with a dead battery in the '05s.
This requirement alone and failure to heed it would, without a doubt, account for some of that "vast majority" of dead batteries turning up in manual '05s which you speak of.
Indeed I do have a Priority Start. I also have my Battery TenderPlus from my C5, and Priority Starts will be going into my other vehicles and my wife's car as well.
But please do tell the whole story. The reason for the Battery Tender is because I live in the Northeast and "store" the car during the winter leaving it sit for weeks at a time in an unheated garage. It is to keep the battery properly charged/maintained while the car is not in use or in minimal use during the winter. It has been off the car since it was taken out of storage when the weather broke.
The Priority Start is to prevent the battery from succumbing to any parasitic drain. As mentioned before, they will be installed on my other cars for the same purpose as soon as they are here.
While I was getting my defective AC/ Delco battery replaced, the service manager mentioned that 2 other same Ac/ Delco batteries were also found to be defective the same week on other GM cars.
