window question
Old May 5, 2006 | 09:07 PM
dbirdhouse1's Avatar
dbirdhouse1
Default window question
As the weather has improved here in the PNW and the windows go down, I noticed that the passenger side window doesn't go quite all the way down leaving a fraction of an inch lip of glass showing....it opens and closes just fine....is this normal?
thanks y'all
Old May 5, 2006 | 09:37 PM
Vette_DD's Avatar
Vette_DD
No, this is not normal. The window indexing may be messed up.
Raise the window and hold the up switch an extra 3 seconds after the window is all the way up. Release the switch. Then hold the switch in the up position again (without lowering the window) for 3 seconds. See if that fixes the problems.
If it doesn't, you need to take it to the dealer's and let him fix it.
Old May 5, 2006 | 10:01 PM
jabez's Avatar
jabez
All ya gotta do is re-set the window indexing
Old May 5, 2006 | 10:21 PM
dbirdhouse1
Thanks you two....worked like charm, appreciate it
To window question
