Compitition Mode/Traction Control
Old May 7, 2006 | 12:11 PM
Wingrider's Avatar
Wingrider
Default Compitition Mode/Traction Control
Looking at the Owner's Manual, I cannot see a differnce between turing t/c off and going to the competition mode setting. The manual seems to say that in both cases, t/c is off, but active handling stays on. Thus, why have a compitition mode, or a separate command to turn t/c off if the result is the same?
Old May 7, 2006 | 12:13 PM
GasmanZR1's Avatar
GasmanZR1
When you just hit the button once and turn off traction control, the active handling remains on. In competition mode, the traction control is also off, but the difference is that the active handling is less intrusive. It will let you hang it out a little more before intervening.
Old May 7, 2006 | 12:23 PM
TrackNoob's Avatar
TrackNoob
This has been covered many times, but it still seems to generate confusion, so let's see if we can make it simple forever:
There are four domains your car's AH/TC can be in. Not two, not three, not five, but four. Here they are:
1. "Default". This is traction control ON, active handling ON.
2. "Traction Control OFF". (The active handling is still on)
3. "Competition Mode". (Traction Control OFF, Active Handling reduced).
4. "TC OFF/ AH OFF" (press and hold five seconds) Not too smart for most, IMHO.
Old May 21, 2006 | 08:24 AM
TrackNoob's Avatar
TrackNoob
[trying to insert a table....]
Old May 21, 2006 | 09:10 AM
mountainlover's Avatar
mountainlover
Old May 21, 2006 | 09:20 AM
TrackNoob's Avatar
TrackNoob
hmmm. No HTML... seems like we used to be able to... oh, well.
Old May 21, 2006 | 11:14 AM
jazzlove's Avatar
jazzlove
From: San Antonio Texas - Any sufficiently advanced technology is indistinguishable from magic
Very true
Old May 31, 2006 | 10:53 PM
ShockwaveGT's Avatar
ShockwaveGT
Does comp. mode alter the way the car uses gas or anything like that?
I'm asking just because I've thought that the car feels more "fun" to drive day to day with comp. mode, but I'm curious if it will effect gas milage...
To Compitition Mode/Traction Control
