Thermostats
Old May 8, 2006 | 06:45 PM
blkvette1's Avatar
blkvette1
Default Thermostats
What's the deal - mine car runs almost always at 196 - 210.
Why do some members think a change to a 165 degree thermo would be a good idea.
Thoughts here?
Old May 8, 2006 | 06:54 PM
jimman's Avatar
jimman
Thoughts here?
Old May 8, 2006 | 07:12 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
Its not just the posters here, but also many tuners will want you to change to a 160 thermostat before getting a tune. IIRC, the higher temp of the stock part is mainly for better emissions and generally hurts performance. You might post your question in the Tech and Scan/Tune sections for better answers than mine.
JJC5's Avatar
JJC5
Do a search on this thread. I had the same question and there are a bunch of answers out there. It's been beat to death. Bottom line? I decided on staying stock. The Gen 3 motors are designed to run hotter. If you do change your t-stat, you'll need to reprogram the fans to come on at a lower temp, otherwise you will have the same temp fluctuations at low speeds. As I have been replied to, the lower temp is not going to increase the density of the intake charge that much.
Old May 8, 2006 | 09:09 PM
FAsnakes's Avatar
FAsnakes
Veteran: Marine Corps
To Thermostats
