Changing Engine Oil (LS2 engine)
Old May 12, 2006 | 03:03 AM
ETHYL's Avatar
ETHYL
Default Changing Engine Oil (LS2 engine)
The owners manual only addresses "Changing Engine Oil and Filter (ZO6 only)" and identifies an installed torque value for 2 oil drain plugs at 18 lbs ft. Since no information paragraph is written for "Changing Oil and Filter (except ZO6)" is given, can I assume it has 1 drain plug and its installed torque is also 18 lb ft. I am having the oil and filter changed on Friday and I want to have the oil drain plug tighten to the correct value.
Old May 12, 2006 | 09:23 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
1 drain plug and SNUG is fine. No need to get too **** with torque on oil pan drain plugs as long as you don't "gorilla" it. Just eyeball it after you start it to check for leaks. (filter as well) Filters are also snugged. I do my filter by hand to avoid over tightening.
Old May 12, 2006 | 09:25 AM
jnx911's Avatar
jnx911
Just be careful not to overtighten the drain plug, as these will strip very easy.
Old May 12, 2006 | 09:27 AM
easyrider13's Avatar
easyrider13
That's good advice. I've never used a torque wrench on a drain bolt.
Old May 12, 2006 | 11:14 AM
D-ROCK's Avatar
D-ROCK
Snug is fine. I also tighten the filter by hand.
Old May 12, 2006 | 11:29 AM
cthusker's Avatar
cthusker
.... sometimes we get TMI when it comes to something as simple as an oil change!!
Old May 12, 2006 | 11:31 AM
JmpnJckFlsh's Avatar
JmpnJckFlsh
If you're having a service monkey change the oil, then they'll probably think you're a space alien if you ask them to torque the oil plug. On the other hand, 18 ft-lb IS the correct torque for the both the Z06 and the LS2 drain plugs.
Having worked on cars almost since puberty, I grew up disdaining the use of torque wrenches. As tight as you could reasonably get them was the rule. That was back when cars were made out of iron and steel. Now that my cars have a lot of aluminum on them, I use a torque wrench on virtually everything...one bad experience is all it will take to help you see the light.
Old May 12, 2006 | 11:38 AM
User 81424's Avatar
User 81424
Something to look for at an oil change and a sign that they know what they are doing. They will use the full ratchet handle when taking the plug off but will choke up or move their hand to the ratchet head to tighten it so they don't over tighten.
To Changing Engine Oil (LS2 engine)
