I'm taking my Z51 coupe for its first trip to the dealer tomorrow. Among the things I want fixed are the squeeling brakes. I've called to find out what they would do. The answer I got was "GM recognizes the brake squeel is a problem but until they have a fix they are temporarily doing nothing under warranty".
While I'm not happy about this response, I'll live with it. The dealer did say they would replace the pads at N/C if I bought them. They also said they recommend turning the rotors. This is the issue. For a car that just turned 16K miles, if the have them install the Gene Beans (ceramic I think) replacement pads that I bought, do I need to turn the rotors?
There was a GM Service Bulletin regarding brake squeal that was active couple of months back. Do a search for "brake squeal". The bulletin provided for the dealer to replace pads at no cost.....a number of Forum members had that service done. If the bulletin is no longer active & the dealer is willing to swap out pads you've bought, for no cost, that's not a bad deal.....and unless the rotors show signs of scoring, there's no need to have them cut. That's just the dealer's scam to get some $$$ off you.
Reason: spelling error
the dealer is correct . GM came with service bulletin and yanked it in March. The ceramic pad will fix the squealing and dust. As far as turning the rotor they need to do it for the new pad to seat well from the onset.
Check out the Technical Bulletin re: 2006 Brakes at this website: http://www.corvetteactioncenter.com/....php?qstId=568
and you''ll see that they are using a different brake pad on the 2006
Z51s. You don't need to go to a different brand of pad, just get yours updated. I have a 2006 Z51 and I have no brake squeal.
Thanks Nifty C6. I believe the pads Gene Beans has been selling on the Forum are the updated pads you are speaking of. What about re-surfacing the rotors?
Thanks to the both of you. The only problem is one says resurface rotors, the other says no.
I understand getting the pads to seat is important. Can't the pads just as easily conform to any wear on the rotor?
Keep in mind, we are talking about a car with only 16K miles.
"and unless the rotors show signs of scoring, there's no need to have them cut. That's just the dealer's scam to get some $$$ off you."
What the dealer doesn't tell you is that this process will also cause your rotors to warp much easier. Rotors are not like what they used to be, turn them now and they will warp the first time you have to make a hard stop.
Thanks 30YR W8T. My gut tells me not to turn the rotors but would rather rely on the experience of others.
Accelerate to about 80 mph on clear-dry road.
Get on the brakes HARD, but not enough to engage the ABS;
When slowed to about 10 mph, release brakes and acclerate to 80 again.
Repeat twice, then drive moderately for at least 10 minutes before any complete stops.
Usually works for several thousand miles before needing repeat.
Then it's a 4 wheel rotor replacement - about $750 ? (Help here guys)
New pads willn seat well unless there is scoreing on the rotors.
