During my orientation at the Museum, I am told that my new Corvette does not have a spare tire or even a jack. Run flat tires! Frankly, I didn’t know this. So here is my question:
Let say I’m in the middle of Iowa, Mechanicsville Iowa for example. I am on a country road surrounded on all sides by nothing but corn and soybeans and I get a flat. Now I understand that I can drive at a reduced speed on the run flats, but then what? I doubt that the Mechanicsville garage has a Goodyear run flat tire in stock that fits my Corvette.
Can you patch this tire?
Can you plug this tire?
I would like to hear from forum members about their experiences with a flat tire on run flats.
If you don't run the tire too far (Owners manual says 25 miles or less), tire can be repaired with a combination plug/patch. I ran one 80 miles, and have to replace the tire.
Repair may be a problem without a GY tire store or other competent tire repair store within an easy drives' distance.
GY does it for free, on warranty up to a point, the first year. Replacement is free also if needed.
A proper repair demands a very competent store, able to tackle runflats and not damage the rims, or pressure sensors. It requires a 'mushroom' type of plug/patch combo to ensure the speed rating of the tire is retained.
I've had 5 runflats fixed over the years and really appreciate not having to do the roadside mumb-jumbo, but instead carefully drive to a repair shop that day, or the next day. Once I had a guy come out and do a temporary plug, as I had to go 30 miles to get home. Out of 5 repairs I've had only one minor case of rim damage. And this is in a small town.
Goodyear says 150 miles. Dave Hill said the same thing. Almost anywhere in the lower 48 you should be within 150 miles of a Goodyear certified repair center. I drove nearly a full 150 miles on a flat, Goodyear was still able to repair it. 22,000 miles later, it is still on the car and doing fine.
OTOH, I had another flat that was non-repairable. I only drove 6 miles on it, but that didn't matter since the gash in the tire was too large to repair. Goodyear replaced it. The important point is that even with severe tire damage, you aren't stuck. The car will still be driveable.
That's good to know. Even though I only drove 80 miles on the flat, I am having it replaced since it was an accident situation (valve stem sheared off), and I don't feel confident driving that tire at high speeds--the lettering was worn off of the sidewall. Also, insurance covers the cost. I tried to get a regular valve stem installed on a temporary basis until I could get a new air pressure sensor. Tire shops won't do it--they say they can't disable a sensor (by law).
From: Heaven, for the climate; Hell, for the company
Originally Posted by 6 speed Sid
Carry a plug kit and a small compressor in case you are really in the boonies. Tire Rack has a nice compact kit with it all.
But plugging from the outside (which will chew up belt fabric/steel) will almost certainly void the GY warranty, right, "really in the boonies" notwithstanding.
I was told that with my C5, but they 'looked the other way' since I had to drive 30 miles home.
The best way to find an authorized shop is to call Good Year. The number is in the warranty and owners manual case. It can be any authorized shop and they are not all Good Year shops.
