Climate Control Display Flashing?????
Old May 21, 2006 | 02:29 PM
StuSegal's Avatar
StuSegal
47 yrs of Vettes
Default Climate Control Display Flashing?????
I got in my car this a.m. ('06 C6 Coupe) and the Climate Contol display is flashing.
The climate control seems to be operating ok, in both automatic and manual modes - but the display keeps flashing.
Has anyone seen this, or know what it means?
Thanks. . . .Stu
Old May 21, 2006 | 03:05 PM
VET4LES's Avatar
VET4LES
I haven't seen it but you could disconnect the battery and see if that stops it. You will need to re-index the windows when you reconnect it.
Old May 21, 2006 | 04:33 PM
calemasters's Avatar
calemasters
It indicates that it requires service. I would try the battery disconnect (above) first to see if the HVAC control will reset.
Old May 21, 2006 | 05:09 PM
StuSegal's Avatar
StuSegal
47 yrs of Vettes
Default Anything else to reset?
Except for re-indexing the windows, is there anything else that dis-connecting the battery affects? (security system, keyfob settings, etc)
Old May 21, 2006 | 05:11 PM
VET4LES's Avatar
VET4LES
From what I have read on the forum the windows are the only thing. Let us know what happens.
Old May 21, 2006 | 06:21 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Just the Windows.
The flashing may be a result of not applying Zaino
Old Jul 4, 2006 | 11:28 PM
HoleInOne's Avatar
HoleInOne
Thanks. . . .Stu
I have this problem also. Did you find out what it means?
Old Jul 5, 2006 | 07:52 AM
StuSegal's Avatar
StuSegal
47 yrs of Vettes
Default Not sure.
Well, if I do nothing eventually it goes back to normal.
The only thing I realized is it seems to only happen when/after I've had Keyfob #2 in the car. Maybe it's a coincidence, or maybe not.
Do you have any ideas/thoughts on what causes this?
Old Jul 9, 2006 | 12:41 PM
HoleInOne's Avatar
HoleInOne
Got mine fixed. New control head and alternater. We'll see if that does it.Oh, also got 06 ***** on the new unit. bling!!
Old Jul 9, 2006 | 02:33 PM
StuSegal's Avatar
StuSegal
47 yrs of Vettes
Default ???
What the heck is a "control head"?
Old Jul 9, 2006 | 06:26 PM
HoleInOne's Avatar
HoleInOne
HVAC control head. That is the component in the dash that contains the controls and numbers.
Old Jul 9, 2006 | 06:29 PM
timd38's Avatar
timd38
Did they give you ***** for the radio so that they would match?
Old Jul 9, 2006 | 06:30 PM
HoleInOne's Avatar
HoleInOne
I have the nav radio and only one ****. Is it different on the 06?
Old Jul 9, 2006 | 06:45 PM
timd38's Avatar
timd38
I don't have NAV, but the radio ***** and the HVAC ***** have chrome rings on the 2006.
Old Jul 9, 2006 | 09:46 PM
DJS819's Avatar
DJS819
Same as mine, 3200 miles and it went nuts. It's the head unit. definately a Dealer service, but it was quick and painless.
Old Jul 10, 2006 | 12:52 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
The climate control is delaminating.
Old Jul 10, 2006 | 01:02 PM
StuSegal's Avatar
StuSegal
47 yrs of Vettes
Default Delaminating?
Delaminating ???????
To Climate Control Display Flashing?????
