Oil level Variation
Old May 23, 2006 | 11:46 AM
SMJBA's Avatar
SMJBA
Default Oil level Variation
I am at lost with an explanation and hope that some you have have insight... I did my oil change Saturday then went of a ride ...left the car sat for the night. Sunday check the oil level ..It read just below the top hole...then went for a ride. Car sat overnight. Monady morning check the oli level. It read 1/16 above the top hole. I am not concern at the level per say but just lost at an explanation for this variance...wich is about 1/4 of of quart I do not beleive moisture content could account for that much. The only other thing i can think of is the oil cooler draining back in the pan if there is no back flow valve. The car was parked both time at the exact same spot..any idea
Old May 23, 2006 | 11:58 AM
millpond's Avatar
millpond
Maybe a variation in the overnight times? In any case shouldn't be anything to worry about.
