Removable top recall
Old May 28, 2006 | 07:39 PM
SDCEB's Avatar
SDCEB
Default Removable top recall
My dealer called me today to tell me that I should bring in my '06 coupe for the recall on the roof. I know the problem, but he didn't know what the fix was for the top. Does anyone know if they are replacing the top, or using some patch for the problem. If this has already been asked, I'm sorry.
Old May 28, 2006 | 08:00 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
At this point glue. Pending GM fix.
Old May 28, 2006 | 08:02 PM
SDCEB's Avatar
SDCEB
I thought that I heard that it was a clip?
Old May 28, 2006 | 08:05 PM
Larry B.'s Avatar
Larry B.
Do a search... There are hundreds of posts on this. More than you will want to read. No offense intended. Just saves everyone from repeating themselves.
Boozman's Avatar
Boozman
Mine was fixed with a two part epoxie
Old May 28, 2006 | 08:06 PM
SDCEB's Avatar
SDCEB
Again, I understand the problem. It was just yesterday that GM said that they were recalling all 05 and 06 coupes.
Old May 28, 2006 | 08:08 PM
SDCEB's Avatar
SDCEB
Got it, thanks.
Old May 28, 2006 | 08:11 PM
LS WON's Avatar
LS WON
If you aren't experiencing any problems at this point in time I would just wait and see what hapens as we get closer to the March 2007 deadline because from what I hear the dealerships are getting the foam onto the painted top which results in GM having to get you another painted top and matching the paint comes to mind along with the risk of dealer messing up your second or third top again getting the foam on the paint.
Old May 28, 2006 | 08:39 PM
Low12s's Avatar
Low12s
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
Not true. Glue if no evidence of separation. If you have separation, they need to replace and paint the entire top.
Old May 28, 2006 | 08:43 PM
VET4LES's Avatar
VET4LES
I'm waiting for awhile but I'm surprised the dealer called. Maybe their drumming up business.
Old May 28, 2006 | 08:48 PM
LS WON's Avatar
LS WON
Plus figure there will be more recalls and maybe they will improve the remedy for this top problem so then you can bring the car in once to do all of the recalls and get a better fix on the top problem wishful thinking.
Old May 28, 2006 | 09:53 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
please check the links above....
Old May 29, 2006 | 06:53 AM
Big Jimm's Avatar
Big Jimm
Specifically what vin numbers are effected?
Are the ones coming from the factory today "fixed?" Mine was built about a month ago.
Big Jimm
So. Fla.
Old May 29, 2006 | 07:06 AM
Larry B.'s Avatar
Larry B.
Big Jimm
So. Fla.
It appears, according to the lastest NHTSA recall statement that the new panel is treated to the foam injection "fix". Is it really fixed?..... Only Time will tell. I asked that question to GM customer service.... waiting for an answer.
Old May 29, 2006 | 08:24 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
To Removable top recall
