Code Reading C6....
Old May 29, 2006 | 01:23 PM
Comp Cam 1's Avatar
Comp Cam 1
Banned Scam/Spammer
Default Code Reading C6....
Well it looks like it may be time to purchase a C6. My question is do I need a special code reader to check the codes or can I do it the same as my C5? If I need a code reading device what one do you guys own. I am still searching for the right car, but would like to have one if needed. Thanks Sixty4.
Old May 29, 2006 | 01:29 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Greetings,
Good luck in your search. You will need a code reader. Here is a good thread in C6 Tech with a couple of choices for you.
http://forums.corvetteforum.com/show....php?t=1396312
I just came from a '97 and I couldn't be happier. You won't regret it (other than no longer being able to clear our codes...
Here is link to a write up I did with my first impressions from the C5 to the C6 for you.
www.theredlion.us\C6.htm
Paul
Old May 29, 2006 | 01:32 PM
Comp Cam 1's Avatar
Comp Cam 1
Banned Scam/Spammer
Thanks Paul. I drove a friends last week. WOW is all I can say.
Old May 29, 2006 | 01:56 PM
talon90's Avatar
talon90
NCM Ambassador
Hell yeah, I had the same feeling when I drove one.
Paul
Old May 29, 2006 | 02:39 PM
Comp Cam 1's Avatar
Comp Cam 1
Banned Scam/Spammer
I currently own a 01 vert. I plan on keeping it. Any good advise on what to look for. I will be buying used as I just can't afford a new one. I do want another vert. I usually check all body panels and do the car fax thing, I will also check the codes on this one. Anything inherent to the C6's I should be looking out for. I strayed a little from the original post (sorry). Thanks Mark Sixty4. All help is WELCOME.
To Code Reading C6....
