When was this VIN built??
Old Jun 2, 2006 | 09:57 AM
hawaiianswiss's Avatar
hawaiianswiss
Default When was this VIN built??
Can someone tell me when this car was built?
Thanks a lot!
1G1YY26E465129051
Old Jun 2, 2006 | 12:42 PM
fenderowner's Avatar
fenderowner
Thanks a lot!
1G1YY26E465129051
I think you can find the build month and year on the door sill info sticker...not with my car right now, so can't verify, but think I read that here on the forum.
Old Jun 2, 2006 | 12:51 PM
Mark923's Avatar
Mark923
Thanks a lot!
1G1YY26E465129051
Ask your dealer to download a Build Sheet for you. It will give you the date. My VIN is 65124xxx, and the Build Sheet shows a build date of April 4, 2006. It takes 36-40 hours for the car to be completed once the build starts.
Some of the parts may show a month earlier, because that was their production date. But the specifics for your car will be reflected on the Build Sheet.
On mine, the April 4 date is the same as the dealer received from Chevrolet two weeks in advance telling them when the build would start.
Old Jun 2, 2006 | 12:53 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Thanks a lot!
1G1YY26E465129051
VIN 1G1YY26E465129051
VEHICLE BUILD
Merchandising Model : 1YY87 -2006 CORVETTE Z06 2 DOOR
Gross Vehicle Weight Rating : 1638 kg (3612 lb) Order Number : 219345
Build Date : 05/15/2006 Build Plant : 165Y
OPTION CODES
#XC AAB - MEMORY PACKAGE
AJ7 - AIRBAGS, RONT & SIDE IMPACT AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
AU8 - REMOTE ENTRY LOCK CONTROL AX4 - EUROPEAN SEAT BELTS CONVERSION
BAG - EXPORT PARTS PACKAGE BGR - BOWLING GREEN PLANT
B4H - EXPORT MOD NOISE CONTROL CE4 - HEADLAMP WASHERS
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE CT1 - COUNTRY OF BELGIUM
DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV DD8 - OSRV
D42 - LUGGAGE SHADE EXP - EXPORT-I.P.C. PROCESS OPTION
FE4 - Z06 SUSPENSION GU6 - REAR AXLE 3.42 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 J56 - BRAKE SYSTEM POWER
KA1 - HEATED SEATS K63 - 110 AMP GENERATOR
LS7 - 7.0 LITER SFI V8-505 HP MAE - MARKETING AREA-EUROPE PROCESSING OPTION
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
NK4 - LEATHER WRAPPED STEERING WHEEL NP7 - EEC APPROVED STEERING COLUMN
NT4 - EMISSIONS SYSTEM EEC QL9 - Z06 POLISHED ALUMINUM WHEELS
R9I - E-FLEET #7 SSG - GRAPHIC SWITCH FUNCTION SYMBOL
T62 - DELETE DAYTIME RUNNING LAMPS T79 - FOGLAMPS, REAR
T84 - EEC HEADLAMPS T90 - SIGNALING & MARKER,EXPORT
T93 - SPECIAL TAIL & STOP LAMP UA2 - ALARM SYSTEM
UH3 - LOW TIRE PRESSURE INDICATOR ULS - LOCK CONTROL STEERING COLUMN
UL2 - EUROPEAN RADIO FREQUENCY US3 - ANTENNA DIVERSITY
US9 - CDX RADIO U19 - SPEEDO INDICATION UNIT:MPH WITH SUB KPH
U52 - ELECTRONIC INSTRUMENTATION U65 - SPEAKER SYSTEM 7, PREMIUM
VC5 - PRICE LABEL SHIPPING VH5 - VEHICLE IDENTIFICATION
VJ4 - CHILD SEAT WARNING LABEL VL4 - FRONT MOUNTING LICENSE PLATE PACKAGE
V76 - TOW HOOKS V78 - LESS CERTIFICATE OF COMPLIANCE
XFA - TIRES, FRONT P275/35ZR18 YFJ - TIRES, REAR P325/30ZR19
02I - INTERIOR TRIM COBALT RED 023 - INTERIOR RED TRIM COMBO LEATHER
1SA - CORVETTE COUPE BASE EQUIPMENT GROUP 67U - MACHINE SILVER
Old Jun 2, 2006 | 01:16 PM
Dave@Ciocca's Avatar
0Dave@Ciocca
Former Vendor
This car was built on 5/15/06, but here's the strange thing...
the car has an inservice date of 6/15/06? Since today, is 6/2/06 why is the car already in service...in the future?
Old Jun 2, 2006 | 01:38 PM
legalgus's Avatar
legalgus
Export?
Old Jun 2, 2006 | 02:06 PM
RPOZ51's Avatar
RPOZ51
From: For the strength of the pack is the wolf . . . . . . and the strength of the wolf is the pack.
Maybe it's a DeLorean.
Old Jun 2, 2006 | 03:20 PM
hawaiianswiss
Thanks guys!
I live in Switzerland that`s why it`s labeled export. Does this car have Navigation? I didn`t see it listed there?
Can someone check if the car has been shipped yet?
Thanks!
To When was this VIN built??
