maybe a dumb question but i was wondering what the if someone could tell me exactly what the difference between the traction control off and the competitive driving mode is? it feels the same. maybe just haven't run it hard enough...
There are two systems using the TC switch - Traction Control and Active Handling.
Traction control is just that - uses the ABS and adjusts engine output as needed to keep the rear wheels from spinning.
Active Handling is stability control. It uses ABS and adjusts engine output to keep the car pointing in the direction you wish to drive. To do this is uses yaw sensors and your steering input to determine when the car is not moving in the direction you want.
Competitive driving mode basically turns TC off, while leaving AH on.
Wrong. Traction control threshold is reduced and AH is truly a competive mode with a far greater variance allowed in the parameters but is still active.
Traction Control Off means just that, it's off. Not "threshold reduced", OFF. Active Handling in the competive mode has reduced interference.
There is no in-between mode with Traction Control, it's either on or off. Active Handling can be on, off or in Competetive Mode.
This has been covered many times, but it still seems to generate confusion, so let's see if we can make it simple forever:
There are four domains your car's AH/TC can be in. Not two, not three, not five, but four. Here they are:
1. "Default". This is traction control ON, active handling ON.
2. "Traction Control OFF". (The active handling is still on)
3. "Competition Mode". (Traction Control OFF, Active Handling reduced).
4. "TC OFF/ AH OFF" (press and hold five seconds) Not too smart for most, IMHO.
So if I want to dragrace someone I should turn everthing off?
Not unless you want to hit a wall, or another car. Go to competition mode. Leave AH on, at least partially. This will not reduce your time, but will help prevent an accident should disaster strike. What kind of disaster could possibly happen? How about hitting a slick spot, a spill of oil or another substance, or simply getting too wiggly on a 2-3 shift.
I have the A6 tranny on my C6 will this thing get sideways like a manual tranny?
It could; there's a lot of power there. Don't forget about the unsure nature of the track. They do their best to preserve the track and keep it clean, but it isn't policed btw each run. There's no good reason to take AH off. It's not perfect, but I'd keep it on anyway.
Read this thread. This guy did have AH on, but nonetheless, it will serve as a reminder that while usually safe, things can go wrong at the strip.
