Does anyone know where I can purchase the splash quards that were offered on at Pipedreams.
My splash guards they are offered not where else. Some have copied them but I have yet to see feedback on them, the copies I saw had some undercoating sprayed on them. If I can find the correct material (because I won't settle for cheap plastic), I will be making them.
I guess the Z06 is an 18 wheeler too. They are built it.
LEX
Looks a lot better than the aftermarket ones. Chevy should put them on every C6 they build not just the Z06. All the aftermarket guards look tacked on not designed in like the Z06's.
pipe dreams
Hi it is barry from newton falls , ohio
I installed my flaps today and they look great.
the instructions on which way to put on the clips for the rear says one way but, your illustration shows it just the opposite.
Barry
pipe dreams
Barry
"Make surer the clip side with the larger lip and spikes faces the rear of the car and that the smooth side of the clip is on the flap."
are you sure you have mine the text and the picture matches
