Recall
Old Jun 6, 2006 | 09:34 PM
Perry Mason's Avatar
Perry Mason
Default Recall
My '06 Coupe was born on 12-19-05.
I called the dealer, and no recall on the roof panel or any other problem.
Am I safe from recall for the roof panel?
Great vehicle, as all my Corvettes have been!
Old Jun 6, 2006 | 09:41 PM
VET4LES's Avatar
VET4LES
I'm sure nobody is safe. One member while at the factory was told that new Corvettes are getting the same roof with no changes. It sounds like every roof installed on a C6 including the Z06 could have a problem. We need to see what the recall letter says. A/o now I don't think anybody has received one.
Old Jun 6, 2006 | 09:42 PM
scottypman's Avatar
scottypman
I saw a guy today at courtesy chevy with a black 06, and his roof was delaminating.......yes you should be worried
Old Jun 7, 2006 | 12:02 AM
achilds's Avatar
achilds
You should register on GMs owner center, www.gm.com. After you register you can check to see if there are any recalls on your car. I don't think there is an official recall out for the tops, or if there is it is just on a small range. Since we don't know what GM has done to figure out what VINs are impacted we will just have to relax and wait.
Old Jun 7, 2006 | 12:03 AM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
I have the same build date and no recall and no problems so far. I expect a letter in the mail soon, though.
Old Jun 7, 2006 | 12:08 AM
vette1003's Avatar
vette1003
Glad i have a Vert
Old Jun 7, 2006 | 02:09 AM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Originally Posted by vette1003
Glad i have a Vert
Old Jun 7, 2006 | 02:26 AM
LS WON's Avatar
LS WON
Are you getting any of the signs or is everything solid? Do you live in a very hot area? I wouldn't let them mess with it until you know for sure something is wrong with your top and usually it seems to be there are early warning signs.
Old Jun 7, 2006 | 02:30 AM
LS WON's Avatar
LS WON
I went to this site it is for building your own car or to receive E-mails on models. Where is this registry for recalls?
Old Jun 7, 2006 | 08:24 AM
Deftly's Avatar
Deftly
You wait at your own risk. All tops are subject to delaminating. You can tell if you are having a problem if you push up (not real hard) on the headliner and hear a crackling noise. Do this standing still or you might pop the top off if has become weak. My roof began delaminating at the rear around the rear latch. Bottom line, get the top inspected, don't wait for a recall. This problem is not limited to vin numbers.
Old Jun 7, 2006 | 08:43 AM
vertlove's Avatar
vertlove
Glad i have a Vert
Another biggy to remember when we have Vert Vs. Coupe discussion next.
Old Jun 7, 2006 | 09:26 AM
flaskier99's Avatar
flaskier99
Mine did not fall into the vin range and was built about 3 weeks before yours was. My top separated and is now in shop waiting for new one.
Old Jun 7, 2006 | 01:21 PM
LS WON's Avatar
LS WON
Push up from the middle of car middle of car? or push up near rear latch? I don't want to end up breaking it. "If it ain't broke don't fix it".
Old Jun 7, 2006 | 06:33 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
With the recall being announced and all these posts on the forum, I've become delamination paranoid. Every small noise and I'm thinking the top has started to come loose.
I've started checking every few days by pushing up on the soft headliner (which is glued to the top skin) at six points, each corner and middle forward and rear. So far, the top does not seem to be moving.
Old Jun 7, 2006 | 06:37 PM
Zymurgy's Avatar
Zymurgy
Moderator
www.mygmlink.com
You have to register your VIN # in order to get recall info.
coolcat's Avatar
coolcat
Glad i have a Vert
Glad I only have a transparent top.
Old Jun 7, 2006 | 06:38 PM
LS WON's Avatar
LS WON
Careful you don't want to create any problems neither.
To Recall
Old Jun 7, 2006 | 06:39 PM
LS WON's Avatar
LS WON
Originally Posted by Zymurgy
www.mygmlink.com
I'll try again besides don't have VIN # with me now will try again later.
Old Jun 7, 2006 | 06:42 PM
crazyeddie's Avatar
crazyeddie
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
You have every right to be paranoid. When my car was perfect at 7000 miles, I was paranoid about the gas gauge. BINGO, GOT IT. Then with all of the threads about your car going dead, BINGO, GOT IT. Then all of the talk about delaminating tops, BINGO, GOT IT.
Old Jun 7, 2006 | 06:46 PM
xs650's Avatar
xs650
Glad i have a Vert
We all have verts, it's just that some of you knew it when you bought them
