Nav Problems
Old Jun 7, 2006 | 12:58 PM
1811Vette's Avatar
1811Vette
Default Nav Problems
The Nav in my 05 C6 has been acting up. On a few occasions I forward through the menu and then when I go back to the main screen half of the touch screen buttons arent highlighted. Although you can see their shadow, they arent highlighted so you cant use them. Typically it is the top row of the first menu with the destination screen.
If I take out the DVD and replace it, the menu seems to work again.
Any ideas?
Old Jun 7, 2006 | 01:22 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Any ideas?
Always start with the simple/apparently obvious when troubleshooting so please don't take offense...
Are you moving when these buttons aren't available by any chance? Some things are locked out when the car is not in motion.
Next time you pop the DVD out see if it needs to be cleaned. If it does just use a soft cloth and go straight across the disc, do NOT go in circles.
Old Jun 7, 2006 | 01:33 PM
kmthor00's Avatar
kmthor00
Same exact problem with my 2006! Top row of buttons are not lit up & can't be used. anyone have any idea? Car is about 2 months old & it just started.
Old Jun 7, 2006 | 01:46 PM
CMEPASU's Avatar
CMEPASU
see if you can isolate a specific time or situation when it's doing this. On my 05 I was on the interstate a couple weeks ago and could not enter a destination while I was driving. I stopped at an exit to use the bathroom, came back to the vette and all was well. Go figure.
Old Jun 7, 2006 | 01:58 PM
mpuzach's Avatar
mpuzach
The system is designed to not allow destination entry while driving.
Old Jun 7, 2006 | 02:04 PM
DrivnXcitment's Avatar
DrivnXcitment
When you are going over (I believe) 6mph the nav buttons are disabled except for already stored waypoints and emergency features. You will not be able to manually enter destinations or points of interest until you are stopped or under 6mph. Its a "safety" feature that GM put in to prevent people from trying to enter stuff and not looking at the road. If it does not work while the vehicle is completely stopped then you have some other kind of problem.
Old Jun 7, 2006 | 04:44 PM
1811Vette's Avatar
1811Vette
No offense taken. I have cleaned the disc. While there are some items that are locked out while the vehicle is moving, these arent. Like I said it is intermittent. While moving the buttons are there, I scroll through all the option to the end menu and then back out and they are gone. While still moving, the disc is removed and reinstalled and they reappear and are working.
Old Jun 7, 2006 | 04:52 PM
saplumr's Avatar
saplumr
Yep! I believe most Nav systems will allow limited access while driving.
To Nav Problems
