Glass Roof Questions
Does the glass roof allow sun into the cabin that will fade the interior?
Is the facory tinting effective?
Is there a shade available that looks good and works?
The factory tinting is a dark blue, sort of like the strip at the top of some windshields. I'm not sure how effective it is against heat and fading as I don't own a transparent top.
Just my two cents worth, I've had the "glass" roof on mine for a few weeks now. In our recent 95-100 degree weather, the interior gets very hot and if you are follicly-challenged (bald) you will end up with a sunburn from long driving periods.
Regarding possible fading, I suppose any sunlight at all will ultimately do this. It seems to me though that the roof pannel is sufficiently dark, and the light let in by the windshield and windows will be way out in front on fading.
Regarding the "effectiveness" of the factory tinting, this is of course a subjective matter. GM must try to balance transparancy with sunblock effectiveness. To my tastes, they got it just right.
I've owned verts or clear tops on all my Vettes except my C6 coupe. I just ordered one. They work well and provide a (distorted) view of the scenery.
I used mine in my 95 and 99 exclusively here in St Louis and NEVER had any heat/temp related problems. It's tinted sufficiently (at least on the C4 and C5) so as not to fry you or the interior. We got into a typical pissing contest some years ago in a C5 thread and I conducted an experiment by placing a thermometer on my consol and one on the roof of the car and took photos of the temp readings. I did this at NOON, and repeated the experiment the next day with the solid panel in place. There was a 3 degree difference. And it was actually 1 degree warmer on the second day. So I don't believe the glass top has any real impact on interior temps.
Now if someone wants to conduct a similar test on the C6 and post their results I'm sure we'll all be very appreciative.
Tom
Tom
I don't have a glass top on my C6 (yet, its ordered) but I had one on my last C5. The tint was dark enough that you could look directly at the sun with minimal discomfort. I'd say it is like a 5-10% tint. It does heat up a bit more when sitting parked but the AC is good enough to keep it cool. On a bright sunny day you and your passenger look a bit like Smurfs, though...
I have a glass top and live in Central Florida. The inside gets hot if the car is left in the sun. I bought a liner from Downsouth Vettes. It is so well made that its hard to tell it from a factory on one the painted top. It is attached with suction cups. I have had some minor problems keeping a couple cups sticking all the time, but they don't cause a real concern. I highly recommend the liner. It keeps the interior as cool as my painted top that the dealer now owns because it delaminated.
