Program the DIC without Engine On - 2006
Old Jun 9, 2006 | 11:11 AM
TonyC6Go's Avatar
TonyC6Go
Default Program the DIC without Engine On - 2006
On a 2006 Coupe, can someone tell me why GM decided that you need the engine to be on, in order to program the DIC? Why do they not allow you go in and set the options while in Accessory mode? Or am I missing something here because if I put the car in Accessory mode, I cannot access the DIC options?
Old Jun 9, 2006 | 12:51 PM
Buffy's Avatar
Buffy
I'm not sure why they did it that way, but there's a workaround - just press the green circle without pushing in the clutch. Car comes on as if it was running, but engine doesn't start.
P.S. Don't try this when parked two feet in front of a Ferrari! It's always possible that something'll go wrong and it'll start up!
I assume that with an automatic you'd put it in drive and push the green circle - or can you get it out of park without doing so? Very limited experience on C6 autos.
Old Jun 9, 2006 | 12:57 PM
wildjeff's Avatar
wildjeff
Cruising
Press and hold the ACC (not the green circle) button for ten seconds and the car will power on without starting, auto or manual.
Old Jun 9, 2006 | 12:59 PM
Larry B.'s Avatar
Larry B.
Automatics need to have the brake pedal depressed for start.
To Program the DIC without Engine On - 2006
