I just got a mobil one oil change at my local quick lube( good bunch of guys) and I had to get 10w 30w instead of the 5w 30w ,because they were out.
I looked in my manual and it did not say anywhere that I can't use this oil, is it okay to use this oil as long as it is mobil one synthetic?
input apreciated.
input apreciated.
Another victim to the oil quick oil changers. We need to move this entry to that threat.
Nothing will happen. Just put the 5w-30w in next time.
... Don't go tossing out perfectly good EXPENSIVE oil. It will not hurt your engine at all. When you do you next change make sure they have the oil recommended....... in the mean time your machine is will be just fine!
While I do believe that using 10W30 Mobil I is not a problem,You should be aware that the owners manual does state that you should not use any other wieght than specified. Also Mobil I extended service oil does not have the GM spec required for Corvette use (in the event that is what they used). Or it just isn't on the bottle although it IS on the regular Mobil I 5W30. You have to remember that you are dealing with GM during the warranty. If you have any engine issues you do not want GM to have any loopholes to jump through.
I think that everyone agrees that 10W30 is fine. After all, the weather is warm now, and 5W30 and 10W30 are both 30W at running temperature, right?
I can't imagine any conceivable engine damage with this perfectly good oil. We ran it in our C5's, as I recall.
And I can't imagine anyone caring/or telling that the oil is 10W30 vs 5W30 if any warranty work is ever needed for any reason.
Isn't the 10-30 Mobil 1 the "extended life" oil, advertised good for 15K miles, specifically aimed at european cars like bmw? I use that in my Silverado with no problems and wouldn't worry about it in my Corvette either. I understand it doesn't have the GM rating as it has more friction modifiers to lubricate and prolong the valves, which long term MAY diminish the effectivity of the catalytic converters. http://theoildrop.server101.com/cgi/ultimatebb.cgi has this information, but be warned this site attracts an unusual following who live only to discuss oil and oil filters, but never the less has some very good information.
I agree... However ... Having been through an engine problem with another brand of car a few years ago I felt the need to warn. I had to show them all of my oil change receipts. If there is ANYTHING other than what the mfg. requires used (per the receipts) it could create a lenghty battle to get your car fixed. That's my point here.
