Paint protection
Old Jun 13, 2006 | 08:16 AM
rashoe1's Avatar
rashoe1
Default Paint protection
While our 2006 Coupe was parked at work a Pigeon dropped a load on it. I washed it and tried to polish it out but Where it hit and where it splattered it looks like it ate into the clearcoat. Its like it curdled the clearcoat. I tried Meguiars Scratch remover but it wont all come out.
What is the best wax or polish to keep bird droppings , ect. from sticking or eating into the clearcoat in the future ?
Old Jun 13, 2006 | 09:20 AM
Lightning Coyote's Avatar
Lightning Coyote
Old Jun 13, 2006 | 09:23 AM
johnodrake's Avatar
johnodrake
Moderator
I use Ziano
Old Jun 13, 2006 | 09:26 AM
Jus Cruisin's Avatar
Jus Cruisin
It'll probably need to be wet sanded....if there is enough clear left undamaged under the spot. If not it will need re-painting.
Old Jun 13, 2006 | 09:27 AM
wreck111's Avatar
wreck111
REFLEX.... Try and use 2000 grit wet and dry sand paper (WET) to get it out then compound with white and then polish and wax.
Old Jun 13, 2006 | 09:37 AM
Michrider's Avatar
Michrider
No wax is going to be stronger than bird crap and sunlight baking. The only key is to try to get it off quickly before the acids and sun bake it in.
A good wax will give some protection, better than nothing.
If the clear is already funky and a wax/cleaner won't straighten it out, it's going to take abrasives. If you've never done anything like that before may be best to let a body shop do it.
If your capable of detailing out paint imperfections and want to try yourself. You start with the least abrasive material, like a 3M swirl mark remover and hand buff the spot. If that doesn't take it out, move up to the next abrasive like a 3M fine cut. Then med cut. If none of the compounds touch it, way have to use wet sanding.
Once you find the right abrasive to correct, then you work you way back down hand buffing the spot with fine cut, then swirl mark remover, then wax.
Use a 100% cotton towels, turn them often to keep using a clean spot.
Wash them in good detergent like Tide and some Downy in the rinse to make them soft. The compounds you buff while wet, tons of elbow grease. The wax is the only thing you let dry first before buffing.
I like the 3M stuff the best. Especially the 3M swirl mark remover, very good at correcting minor imporfections without adding more.
Old Jun 13, 2006 | 09:39 AM
drrichie's Avatar
drrichie
Any one of a dozen or more polishes will offer some limited protection for that situation. I find that freqency is the key. You simply cannot just apply any product and go through many washings, rains or extended periods of time between applications. Did you try clay bar?
I know another easy method if that doesn't work - PM me.
Old Jun 13, 2006 | 09:47 AM
PapaTango's Avatar
PapaTango
What...big trade secret?? Share your knowledge with the masses, dude.
Old Jun 13, 2006 | 10:09 AM
CodyC6's Avatar
CodyC6
For protection, I use the clay bar, and Paint Sealant from Griot's Garage. Periodically, you can use another way to maintain the protection. I used the clay bar for the first time 2 weeks ago, and if you haven't tried this, it is absolutely amazing how smooth the finish turns out.
Old Jun 13, 2006 | 10:25 AM
shurite44's Avatar
shurite44
I agree, what is the method. This forum is not much use if we play lets keep a secret.
Old Jun 13, 2006 | 01:12 PM
drrichie's Avatar
drrichie
But lets admit that whenever someone's "Cure" is posted you get ten (or more) counter opinions negating your help. My mistake is I shouldn't have posted my "PM me" comment for this very reason (My apologies for sure!). As I write this post there is already 5 different methods and more to come. I guess I should just keep my opinions to myself or roll with the flames.
BTW, Mix Glycerine and a cleaner called Krud Kutter 1:2 ratio rub with a cottenball until bird dirt/berry/tree sap is gone - finish with your favorite polish. (I learned from a Barrett-Jackson employee).
I clean paintings worth hundreds of thousands of dollars as a hobby no less, so I believe I can speak on the subject of cleaning.
Old Jun 13, 2006 | 03:16 PM
shurite44's Avatar
shurite44
I figured that was the reason. I know what you mean about that. Sounds like a good solution though, thanks I will put that in my back pocket for future reference.
To Paint protection
