Mp3 Or Not?
Old Jun 14, 2006 | 10:50 AM
drunkendog47's Avatar
drunkendog47
6th Gear
Default Mp3 Or Not?
Well now. From what I've heard the '06 Coupe plays MP3's in the navigation system.
Does the 2005? Or was that an upgrade in 2006?
Old Jun 14, 2006 | 11:30 AM
mpuzach's Avatar
mpuzach
As set up at the factory, 2005s do not and 2006s do. There's a software update that can be performed on 2005s that allows them to play MP-3s. Many here (including myself) have had it performed and it works great.
Old Jun 14, 2006 | 11:35 AM
Dark Overlord's Avatar
Dark Overlord
i did the upgrade too but i found it to be tooooo sluggish for my liking...
Old Jun 14, 2006 | 11:38 AM
JackBurton's Avatar
JackBurton
I threw in a freshly burned mp3 CD and it would not read it. What sort of format does it need to be in?
Old Jun 14, 2006 | 11:57 AM
Berman's Avatar
Berman
where do you get this update done? at the dealer?
Old Jun 14, 2006 | 12:14 PM
rwpatte's Avatar
rwpatte
It can be done at a dealer, no charge. Usually, they go by S/N on radio. DON'T KNOW ALL THE PARTICULIARS. There is a posting with the software that can be downloaded to a cd and do it yourself. Maybe somebody can point you to the right direction. A lot has been posted on the subject. I did mine. Piece of cake. Works great.
Old Jun 14, 2006 | 12:46 PM
quickride's Avatar
quickride
Here's all the information you need.
http://forums.corvetteforum.com/show...&postcount=152
I did the update myself on my '05 NAV radio and it took only 10 minutes to complete. I love it.
Old Jun 14, 2006 | 01:02 PM
Dark Overlord
yes...
Old Jun 14, 2006 | 06:18 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Everything you need to do it yourself is right in that post. I was done in about 10 minutes and saved a trip to the dealer. It's not for the faint of heart however, there is a phase when the radio goes dark and I was like but everything ended perfectly.
Paul
Old Jun 14, 2006 | 06:22 PM
SunsetC6's Avatar
SunsetC6
I do not have the changer and was so happy when the update came out. Downloaded it and did the update and now I am so happy. Well over 100 songs on a single disc and I never run out of music. Highly recommend you update.
Old Jun 17, 2006 | 11:53 AM
PTI 1's Avatar
PTI 1
1st Gear
Default Upgrade software without Nav?
#1 - Does anyone know if the downloadable Nav - MP3 upgrade software will also work on a 2005 without Nav? I have the basic system with 6 disc changer.
#2 - Does anyone know what to tell the dealer to have them do the upgrade? My service tech said there are 31 GM service bulletins for my C6 stereo and unless I can find out which one it is, they cannot do it. (They never heard of it.) Or would one of you that had it done at the dealer, post the tech/dealer info so I can contact them for the info?
Thanks!
Old Jun 17, 2006 | 12:10 PM
mpuzach's Avatar
mpuzach
Thanks!
If you don't have nav you don't need the update - your CD payer already should play MP-3s. The update only applied to 2005s with nav.
Old Jun 17, 2006 | 02:45 PM
PappyTinker's Avatar
PappyTinker
From: Life ain't no dress rehearsal, are you gonna wait to get your toys til AFTER you have a heart attack?
The format is MP3 but it depends on how you burned it. If you just copied files, that won't work. You need to use a burning program such as MusicMatch or RealPlayer. Nero or Sonic may also work but I have no experience with them. Is the burner in your PC different from the CD drive? Does the CD play in the CD drive of your PC? Do you have another player that recognizes the MP3 format.
Old Jun 17, 2006 | 02:50 PM
PappyTinker
Yes, a fully loaded 700Mb CD has the capability of storing about 8 1/2 hours of audio if the 128Mb rate is used. More if using a lower rate and less if using a higher rate. The one I recently burned and have in the Vette now has 198 songs on it and there is about 50Mb that I left blank.
Old Jun 17, 2006 | 05:20 PM
TXSTICK's Avatar
TXSTICK
Nero (MP3 disk create) worked fine on my 05.
Old Jun 17, 2006 | 05:29 PM
John Bravo's Avatar
John Bravo
do you notice the sound quality being a bit off. I thought mp3 is compressed and lacks the sound of a wav file.
Old Jun 18, 2006 | 05:42 PM
DryHeat's Avatar
DryHeat
For some reason I missed the original post on this update to the nav. radio. Just did the software update and radio now plays MP3's - very cool- thanks Corvette Forum!!
Old Jun 18, 2006 | 09:24 PM
PoundF15's Avatar
PoundF15
Wav is compressed also...it all depends on the sample rate you use. I think my MP3's are at 144 right now and that's plenty good enough for listening to in the car to my ears...but the higher the sample rate the less you're going to "hear" the compression.
Old Jul 28, 2006 | 04:56 PM
drunkendog47
6th Gear
Default mp3
I did the firmware upgrade myself on my 05 and the mp3s discs play perfectly.
To Mp3 Or Not?
