lighter power?
Old Jun 14, 2006 | 09:07 PM
bighaig's Avatar
bighaig
Default lighter power?
When the car is off (not in ACC mode) devices attached to my lighter still draw power. Does this shut off after a few seconds or minutes? Or will they drain the battery if I leave them on all night?
Thanks,
BigHaig
Old Jun 14, 2006 | 11:26 PM
JohnDS's Avatar
JohnDS
Yes they continue to work. The fuse is 20 amps (check the owner's manual for location) so it can provide a good deal of current.
You should have some concept of the # of amps your device uses before you connect it. If it's greater than 20 you'll blow the fuse.
I would guess the battery is good for about 80 amp hours, so at max power draw it won't hold up overnight (and it's harmful to the battery to deep cycle it).
If the device is like an iPod, and drawing < 1 amp per hour there should be no problem at all leaving it connected.
John
Old Jun 15, 2006 | 12:33 AM
bighaig's Avatar
bighaig
It's a Sirius radio. I am not sure how many amps it draws. So I should not worry about leaving in on all day/night? See info below.
Power ..........................9-16 Volts, Negative Ground
Fuse Requirement ........... 2A ATC
Old Jun 15, 2006 | 08:22 AM
C2Jeff's Avatar
C2Jeff
I notice that my cell phone charger stays lit even if the phone isn't attached to it. I am beginning to wonder if it will keep drawing power if I remove the fob from the car. I'm going to experiment to see if it will keep draining the battery even when the car is left and the fob removed and will report back. Judging by the posts so far, the consensus is that the socket stays hot all the time and will drain the battery, but I need more proof than that.
Old Jun 15, 2006 | 08:28 AM
shopdog's Avatar
shopdog
The accessory power sockets are hot all the time. I would not recommend leaving anything plugged into them with the engine off. Starting batteries can be damaged if more than 20% of net capacity is discharged from them, ie never deep cycle them. So you will hurt the battery if you draw more than about 0.7 amp from it for more than 48 hours without recharging. Ignition switched power is available in the fuse box, hook up there for anything you want to leave connected to the car.
Old Jun 15, 2006 | 12:58 PM
bighaig's Avatar
bighaig
Ok. I will run a few lighter heads from the Ignition switched power.
Old Jun 15, 2006 | 01:11 PM
C2Jeff's Avatar
C2Jeff
Good to know. Saves me from having to improvise that test I mentioned. No more leaving the phone charger plugged in from now on!
Old Jun 18, 2006 | 07:33 PM
JohnDS's Avatar
JohnDS
Hard to figure why a radio would need to be connected all night.
Most radios draw the most amps when they are turned up to the maximum volume. If it is just in the 'on' position and maybe some little light is on with no audio it would be drawing very little power.
The Fuse requirement of 2 Amps means it should never normally draw that much. So let's just say it draws about 1 amp, so yes it is fine to leave hooked up all night.
Of course if it's a C6, it doesn't need a reason to run down the battery, it already has one.
John
Old Jun 18, 2006 | 07:38 PM
VET4LES's Avatar
VET4LES
John
If you know what that is GM would like to hear from you.
Old Jun 18, 2006 | 08:57 PM
johnodrake's Avatar
johnodrake
Moderator
That is exactly what killed my C5 battery.
To lighter power?
