check engine light
Old Jun 17, 2006 | 01:13 AM
moetoes's Avatar
moetoes
Do you have an aftermarket air intake? My crankcase ventilation valve came off causing a check engine light. The service dept. found it right away, problem solved.
Old Jun 20, 2006 | 11:11 PM
Vette66AirCoupe's Avatar
Vette66AirCoupe
My '06 Vert is at the dealers right now with 402 miles on it due to the check engine light. The light came on and I got a message stating "Engine Power Reduced". Since three different dealers couldn't look at it until Thursday I took it to my local garage and he said the code coming up was that the "accelerator pedal position sensor" (P2138) was malfunctioning. He said the reduced power result was probably because the sensor being at fault could result in erratic behavior, like a 6,000 RPM surprise as I'm driving out of my driveway. He checked the connections which seemed to be fine and I drove away with no "Engine Power Reduced" message and the engine light still on as he said, and I agree, that it would be bad to clear the codes without having the dealer check it out. I found a dealer who said they'd try to get it in tomorrow (Wednesday) and dropped it off. By the way, when the car goes into "Engine Power Reduced" mode it runs about as well as Chevette with 200K miles on it. Downright scary! We'll see what he dealer says.
Old Jun 20, 2006 | 11:55 PM
LS WON's Avatar
LS WON
You didn't modify the car in anyway did you? 402 miles is totally unacceptable
Old Jun 21, 2006 | 07:16 AM
AFVETTE's Avatar
AFVETTE
Since C6 owners can't read or clear DIC error codes like in the C5 I ordered a Code Reader even before my car was built. I've used it a few times already. Sure saved me a boat load of time going to the dealer to read and clear a stray code, which these cars are prone to trigger from time to time for no real reason.
http://www.diydiagnostics.com/
Every C6 owner should have one of these in a rear cubby.
Tom
Old Jun 21, 2006 | 09:15 AM
Vette66AirCoupe
LS: No mods yet. She's bone stock. In her defense I have to say I had a nuisance trip to the dealer with my new Grand Cherokee as well. Bad wheel speed sensor caused a slew of warning lights to come on. It's still a PIA and this problem has occured at a most inopportune time for me.
AFVette: My local guy needed both code readers to asess my problem. The OBDII Code Reader and the CAN OBDII Code Reader. He had a different model but when he couldn't get the code with the first one he had to add the Controlled Area Network reader to the loop to get the answer. That puts you at $125 plus shipping and you still may need a trip to the dealer once you have your answer, as was the case with my episode. Still, I agree that it's probably a good investment and will help keep the blood presure down!
Old Jun 21, 2006 | 11:26 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Originally Posted by JmpnJckFlsh
Some things are so elementary, you aren't going to get any codes. I'm surprised your dealer can't guess the cause...maybe he isn't trying very hard.
Inside the console, there will be a little switch that tells the computer when the shift lever is in Park...that switch has either loosened up or needs to be adjusted so that the shift mechanism closes the switch in the Park position.
Everybody is a friggin mechanic now Maybe the car did not act up at all while the tech played with the shifter for 20 minutes. And the shifter assembly is one complete unit that does not really have any replaceable parts. The switch is nowhere near the consol, it is actually part of the shifter assembly, not the center consol. The park/nuetral switch on the trans also plays a part in the lamp coming on, but that all checked out OK.
Old Jun 21, 2006 | 12:53 PM
AFVETTE's Avatar
AFVETTE
I paid $70 for the CAN protocol reader. I had all sorts or codes when I installed my SLP Blackwing. I wouldn't want to take my car to the dealer for those. Armed with the Codes SLP authorized me to return the item. So I spent $70 not $125. And as I said C5's and I suspect C6will trigger codes for no real reason.
Tom
Old Jun 21, 2006 | 02:20 PM
Vette66AirCoupe
Tom
Tom,
My point was that your $70 unit would not have given me the code for my problem. They tried it and found the secondary unit was necessary for my diagnosis. Your mileage may vary.
Old Jun 21, 2006 | 04:28 PM
fenderowner's Avatar
fenderowner
Originally Posted by Virile1973
Maybe you should stop guessing and have someone scan it for DTc's?Is the car under warranty?I do not understand people who come online to have people try and guess why their check engine light is on.Just bring it in if it is under warranty.
Unfortunately, there are a bunch of reasons a CEL will come on, and a whole bunch of those aren't serious problems. Couple this with the fact that it's a pain to take your car to the dealer, especially IF you believe that there is no serious problem associated with the CEL (i.e., the car seems to be running okay, no smoke coming out of your exhausts, no hesitation on acceleration, etc.). Because of my frustrations over the years with CELs on all makes of vehicles, I decided to buy myself a $70 OBDII code reader from Walmart (it's also CAN-enabled, which is a must for the C6). I have had one CEL since I bought my C6, and I immediately pulled the code which turned out to be "detected a slight leak in the emission control system" (which actually turned out to be a loose gascap, I think). Once I convinced myself this was not a major problem, I reset the CEL - and there has been no return of the condition (i.e., CEL has stayed OFF). Bottom line: I saved myself the hate, pain and grief of having to drop my car off at the dealer's, go back and get it, etc. I guess it's "to each his own," but anytime I can avoid having to go back to the dealer, it's a plus for me (my philosophy is that NO ONE will be more careful with my car than I will). HTH.
Old Jun 21, 2006 | 04:35 PM
Vette66AirCoupe
Originally Posted by fenderowner
Bottom line: I saved myself the hate, pain and grief of having to drop my car off at the dealer's, go back and get it, etc. I guess it's "to each his own," but anytime I can avoid having to go back to the dealer, it's a plus to me. HTH.
I hear ya. I just heard from my dealer and he confirmed that it was the accelerator pedal position sensor at fault. The part is not in stock. Took the car in Tuesday afternoon and they won't have the part until Friday morning. He did promise to do it first thing on Friday though. 402 miles...............
