window problem
When I tried to close the door ,it wouldn't close!
I thought well maybe the seat belt was in the way.
I made sure that was not the issue. I closed it again ,and the window was hitting the windshield pillar??
I then relized the passenger window didnt index.
After 2 more tries it returned to normal.
I washed the car,then tried the door and everything was working fine.
Is this because I didnt open the door for a while and it just losened up?
Yep, takes about 30 seconds per window. Raise the window and after it's all the way up, continue to hold the up switch for an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Repeat for the other window, just to be sure.You will need to do this after the battery's been disconnected for any length of time at all.
Thanks,
