Visor Stickers
Old Jun 19, 2006 | 11:24 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by steve J06
I used a heat gun to loosen the stickers and peel them off but this left the expected residue. Bought the goo gone but it dind't seem to touch the glue. How much of this stuff did you use? Did you take the visor off the car, or really soak the glue in it? appreciate any help.
steve
You have to rotate the visor so that the sticker side is facing up and the surface is level to the ground. You have to take the top off (or lower it if a vert) to do this. I then simply moved the bottle across the entire surface of the glue that was left, lightly soaking the area. Let it sit for a moment, then use a stiff bristle finger nail brush or tooth brush to remove the glue. The glue will ball up and come right off. I then simply wet down the surface of the visor with a damp wash cloth or sponge. The goo gone won't harm the surface of the visor. Works best in warm sun light.
By Michael S. Palmer | 2026-06-03 11:00:24
