Window - auto indexing not functioning
Old Jun 20, 2006 | 11:28 AM
Army Vette's Avatar
Army Vette
Default Window - auto indexing not functioning
Just got the car back from the dealer, first oil change, and the driver side auto indexing is not functioning - it stays up.
I had a problem with it staying down before and messed around with it for about 15 minutes and got it working, but no luck this time.
Anyone have this problem? Anyone know a solution?
The window itself is working fine, just that auto indexing.
Old Jun 20, 2006 | 11:30 AM
AFVETTE's Avatar
AFVETTE
Have you tried to "re-index" it? The procedure is in the Owner's Manual and very easy to do.
Power Window Initialize
After a power reconnect such as battery replacement, the
window index-up feature will not function until the system
is initialized. Once power is restored, do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds and release
Tom
Old Jun 20, 2006 | 11:34 AM
quiznos's Avatar
quiznos
Put the window all the way down - Then keep holding the switch in the down position for 5+ seconds
Old Jun 20, 2006 | 11:37 AM
Zymurgy's Avatar
Zymurgy
Moderator
Default The Proper Procedure is...
From page 2-18 of the 2006 Owners Manual:
1. Close the door.
release.
Old Jun 20, 2006 | 11:56 AM
Army Vette's Avatar
Army Vette
Boy I looked at the manual and just couldn't find the info.
I guess i have to read it cover to cover again.
Thanks!
Old Jun 20, 2006 | 11:58 AM
AFVETTE's Avatar
AFVETTE
Thanks!
page 2-18, you do have a 2006 right?
Old Jun 20, 2006 | 12:24 PM
Vette_DD's Avatar
Vette_DD
Sig says it's a 2005. Window indexing is on page 2-17 in the 2005 owner's manual. Lookup "Window" in the index in the back of the manual.
Old Jun 20, 2006 | 02:38 PM
Army Vette's Avatar
Army Vette
The fix is in! Thanks much!
To Window - auto indexing not functioning
