Problem with seat memory
Old Jun 22, 2006 | 11:17 PM
mpuzach's Avatar
mpuzach
Default Problem with seat memory
Here's the problem: I have the "exit" memory position set to push my seat all the way back and down upon exiting. Most (but not all) of the time, when I exit the car the seat stops its rearward travel before moving all the way back. Sometimes it stops just a fraction of an inch short, other times an inch or two. When it stops short of the exit position, it also fails to move to its No. 1 preset position when I re-enter the car and push the number 1 button. In these cases, if I then manually power the seat all the way back (to its programmed exit position) and then push the number 1 button, it will go to the number 1 preset position. I'm ALWAYS using the number 1 fob and the other fob is far from the car. There's nothing behind the seat obstructing its travel. Any ideas what might be causing this?
Old Jun 23, 2006 | 12:30 AM
bocabob's Avatar
bocabob
When in exit mode memory, get in, start and let the memory work.. no need to press the number 1...try it.
Old Jun 23, 2006 | 01:07 AM
mpuzach's Avatar
mpuzach
Incorrect. With the manual transmission, you must push the button in order to bring the seat (and steering wheel) to the preset position.
Old Jun 23, 2006 | 01:13 AM
xlr8rvette's Avatar
xlr8rvette
From: Fayetteville Arkansas recently moved from Oakland Ca
St. Jude Donor '06
I have experienced the same situation. It does this intermittently.
When I reset it it works fine for awhile (ie most of the time) then goes bonkers
I will mention next time go in for service. Consider this to be a minor annoyance. Easily forgotten once I get up and go !
Edit: Have 36,500 miles on Vette. Started this at + or - 35,000 miles
Second edit..every now and then (ie once a month for past 3 months) the radio stations also need to be reset. And there is the occassional Radio (?) noise before engine starts. Whats with that???
Old Jun 23, 2006 | 01:26 AM
mpuzach's Avatar
mpuzach
I haven't had that one happen yet, Bill. I'll report here if I get any answers from the dealer on the seat memory.
Old Jun 23, 2006 | 01:35 AM
xlr8rvette's Avatar
xlr8rvette
St. Jude Donor '06
On a different subject, did you happen to hear anything about the accident at the Cotati exit last Sunday off 101 in Rohnert Park? A Flatbed tow truck with a Caddy onboard went into a House. Unbelieveable sight.
Just curious
Old Jun 23, 2006 | 01:50 AM
mpuzach's Avatar
mpuzach
Just curious
Geez, no, I didn't hear about it. I'm surprised since I drove down to Petaluma and back that afternoon. It must have been a mess!
Old Jun 23, 2006 | 11:55 AM
bocabob's Avatar
bocabob
hmm... didnt realize the MN6 was different from the A6 regarding the memory 'memory'
Old Jun 23, 2006 | 12:31 PM
Vette_DD's Avatar
Vette_DD
For driving position, it is. MN6 folks have to be able to push in the clutch. GM lawyers want the driver to be sure he/she can do that before starting the car.
mpuzach, I'd take a look under the seat to see if something's dragging. I've not had such a problem, but several here have reported things under the seat dragging.
Old Jun 23, 2006 | 12:40 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Had a similar problem in my C5 with about 50k miles, tech replaced some control module (in the door?). Fortunately, I had the extended warranty.
Old Jun 23, 2006 | 12:42 PM
mpuzach's Avatar
mpuzach
Thanks for the tip, Jim. All's clear under the seat.
Old Jun 23, 2006 | 12:44 PM
mpuzach's Avatar
mpuzach
Yeah, I'm thinking that it's probably an electronic glitch that will require the replacement of a part. Sounds like something to have the dealer address.
To Problem with seat memory
