Z06 Grill
"if you can pull the old you can install the new. it is bigger but it is stil the same size as the stock c6 grill. the diffrence is the z has a bigger opening to show more of the grill, so i did not cut anything. i used the drimel tool to grind at a couple of the bars on the grill so it would set flush with the stock c6 bumper but it not necessary"
So, it sounds like a very "do-able" mod to me...
Yeah, I am definitely in. You think he would mind kicking out some specific directions and/or pics. I would really like to see how he did it and what his looks like now. That is too cool. Thanks for looking that up.
Yeah, I am definitely in. You think he would mind kicking out some specific directions and/or pics. I would really like to see how he did it and what his looks like now. That is too cool. Thanks for looking that up. The Best of Corvette for Corvette Enthusiasts
The Z06 is two pieces, a frame and a grill insert.
The C6 is one piece.
The Z06 frame attaches to the fascia extension with four push pins (two per side) and also to the lower body grill opening with four screws.
The one piece stock C6 grill attaches in a similar manner.
These fastening points are required to keep everything in line as most parts in this area are flexible.
Give yourself a few hours to attempt the install.
You'll have to jack the car up, remove the side spoiler pieces, the corner brake cooling intake covers, loosen the lower body section, then work from the back, accessing through the sides and bottom to remove the stock grille. You may want to remove the fascia extension and open it up like the Halltech CAI at this time.
I went through the exercise two weeks ago, but wasn't satisfied with the finished result.
Looks better then the stock C6 grill, but still looks cheap.
Ended up ordering a Mercado grill, which will be my fourth grill mod (stock, modified stock, billet, and hopefully last-Mercado)
That's it.....replacement part, only about $40.00 for the two pieces.
Nice design, but extremely flimsy !!!
Hope this guy finds the thread. I bet alot of guys would buy into a ZO6 grille.
