Found out this morning what people mean when Supercar tires are cold and what "snap" means. I routinely switch to Competitive Drivng Mode every time I fire up my MN6 Z51 up because wheel-spin is fun, but active handling makes it a lot safer. About three miles from my house this somewhat cool early morning in sunny Socal, I overcooked it into the right turn onto the off-camber, downhill onramp cloverleaf and kept the throttle in it for a micro-second too long. In that microsecond, I was suddenly looking out the left window in the direction of travel. Time slowed down as I reacted with slightly reduced throttle and countersteer, a lot more and a lot longer than I thought it should have taken. For half that microsecond I thought, "It's not coming back, uh oh", but then a miracle occured and we were sorted out and headed down the ramp. God bless Active Handling!
The moral of the story is, be ready for the "snap" if you're going to fandango with your C6!
Leaving it on...to each his own, I guess. I leave it on if I encounter rain, but there's no question that in the dry, the acceleration is reduced as the traction management kicks in and auto-brakes long before the ignition cut-out.
Originally Posted by Atomic Punk
+2
the guy at the dealership told me if ya take the emt's off and put regular tire on it, it is a different car.
I drive mine in competitive mode for auto-x but usually leave everything on for street driving. I'm actually wondering if smooth driving at the auto-x might be even more rewarded with everything on as I tend to really cook the rears coming out of hairpins...just cannot keep my foot out of it long enough. Traction control might be better than playing with tire pressures...but I don't really know as this is my first year with this car at auto-x.
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
For autox you will be much better to turn off everything, both AH and TC off. The reason you are cooking the rears coming out of tight corners is because the AH is trying to straighten out the car for you by applying one or the other front brakes causing drag which compounds the wheelspin. Yes it is doing it even though you are in comp mode. Give it a try with everything off at your next autox. I think you will like the results. Dont screw with the tire pressures on stock runflats.
I love spinning tires as much as anyone else, I just think that there is a time and place for everything. Leave everything on while on a public street, take it to the track otherwise. Just my own opinion.
I believe some of the issues can be attributed to the run-flat tires, I had a modded 99 coupe (340 RWHP) and on the run-flats I could get the car to mis-behave anytime I wanted and at times I didn't. They I switched tires to a non-run flat (same size) and the car's behavior improved dramatically. I know the new generation run flat has been improved, but it's still a run flat and there are a few downsides to their nature.
When I bought my 03 Z (w/o run flats) and increased HP from 340 to 367 at the rear wheels, I was surprised how well behaved the Z was. Again I believe the characteristics of the run flat vs a non run flat are at play here, or at least contribute significantly.
Having said all that I have no intention of ever switching from a run flat, I will however change my driving style accordingly.
