Navigation Sucks
I too have found that by ZOOMING in, it has much more granularity with regards to street displays.
My guess is these systems are about a 90% solution and there is no Holy Grail of NAV systems.
Tom
Greetings
I am interrested in a factory NAV. Do you have a price in mind. I would need the nav head unit, DVD and antenna.
regards
I don't know if you have the HUD but I find it very effective in how it interfaces with the Nav and displays information.
Hopefully you can get an update of database for info in your area.
I assure you that when the thing is working the way it should it can really reduce the stress level of moving in unknown areas and reduce the level of intensity with your co-pilot (should there be one).
Anyway that has been my experience with the device.
Good luck.
You are correct about absolutely great nav in Cali. I have the stock nav unit also and it worked tremendously in California. Now I am stationed in Mississippi and the nav is far, far, less than stellar. Half the time it shows that I am not even on a road when I am on a major highway. I just think some of the po-dunk states (ie me in MS), are not mapped very well because half the people here can't even spell GPS much less use it. Although I do love my nav when not in MS.
I told her I expected a, uh, favor for what she'd done, but she ignored me.
Tom
I've found that most of the systems out there, be it the uber-cool Pioneer AVIC series, the Toyota/Lexus systems, the Acura systems, the Chevrolet systems, the Audi systems, the Land Rover systems, and too many others to mention all use the same "base" for their software.
When you're actually mucking around in the binaries, all of these systems look remarkably similar, even though there are significant differences. Denso provides the base "skeleton" if you will, and then it's up to the manufacturer to determine which features it's going to impliment and how. For instance, it appears that the "hooks" are there for our nav systems to play DVDs, but if the actual code is in there anywhere, it's offloaded onto other chips -- the Lexus systems have it built right in to the main program, along with all the climate controls.
There are a few manufacturers, like Infiniti that use a different system, and I think Garmin has their own propriatary format, but they are in the minority. The KIWI formatted maps that Denso uses tend to be the most comprehensive, but just because they update doesn't mean that GM is going to license the latest maps or release an update.
Currently, I'm working on trying to make "hybrid" discs to see if I we can use the map data from other manufacturers. However, getting access to the discs isn't the easiest thing in the world.
HTH
