Problem installing skip shift by-pass harness
Old Jul 2, 2006 | 06:01 PM
Jimbospice's Avatar
Jimbospice
Default Problem installing skip shift by-pass harness
HELP!
Today I’m am attempting to install a MID AMERICA MOTORWORKS CAGS (skip shift) by-pass harness. I have been unable to insert the CAGS harness into the car wiring harness (it will only go in about 1/3 to 1/2 of the way) the male female sockets connectors cannot be pushed home. I have tried channel locks but that only causes the two connectors bind in a sideways motion.
Any suggestions?
Old Jul 2, 2006 | 06:08 PM
Gillvette's Avatar
Gillvette
Check out forum member Bugmans site and got to "Cags By Pass". I'm not sure why it won't connect.
http://81x.com/bugman/c6
Old Jul 2, 2006 | 06:11 PM
VET4LES's Avatar
VET4LES
You may be working on the wrong plug. There is a temperature plug near the CAG's plug. Others have done the same thing.
Old Jul 2, 2006 | 06:13 PM
zbrett's Avatar
zbrett
I think you have the wrong connector. If you look above the connector you are trying to use on the transmission there is another connector. The wire should be labled "Skip shift," or something similar to that.
Originally Posted by Jimbospice
HELP!
Any suggestions?
Old Jul 2, 2006 | 06:17 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Originally Posted by VET4LES
You may be working on the wrong plug. There is a temperature plug near the CAG's plug. Other have done the same thing.
That would be my bet as well. You wouldn't be the first. There is another connector close by.
Paul
Old Jul 2, 2006 | 06:21 PM
2kvetmy's Avatar
2kvetmy
HELP!
Any suggestions?
surely no one is as dumb as i was, when i 1st tried to put the bypass in.,
i spent 2 hrs trying to find/disconnect the blue connector in the transmission, called corvettes of houston twice before i asked" is it right beside the oil filter" ???
whoa, the trans is on the other end of the car was the reply from houston
took 5 minutes after that
ha ha ha
Old Jul 2, 2006 | 06:26 PM
not08crmanymore's Avatar
not08crmanymore
by the way,the 1-4 light will still come on after the install,in case you didn't know.
Old Jul 2, 2006 | 08:48 PM
Jimbospice's Avatar
Jimbospice
Thanks to all the installation is complete.
To Problem installing skip shift by-pass harness
