It's done! C6 Insulation Kit
Cruise-In VII Veteran
Originally Posted by Abomination
I think you guys are focusing to much on the minor points and not enough on the major. I have this on my car (did it myself, didnt realize he was making a kit) and the interior noise is all but gone. I havent seen any interior heat difference, but again this is vegas so I doubt Id see it anyway. The car is much quieter then when I first purchased it. I went this route because I had installed long tube headers, cats and cat back.
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
When I get my Vette, this is one of my first mods I would like to do.
So we will be talking soon.
My question is once you lay all this stuff down do you spray the back of the carpeting with 3M spray to keep it from sliding on the aluminum?
Will the price for the vert model be less than the coupe? Just wondering, 'cause there is less material involved?
I am interested in this product. I notice alot of heat around my console area. I have wrapped my pipes from the cat back through the end of the tunnel. I noticed a small relief, but still needs help.
Les
Les
The Elite Engineering tunnel plate eliminates most of the console area heat.
I installed Dynamat Pro in the doors & trunk, which helped a lot with noise intrusion.
Premium Supporting Vendor
Location: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Yes, Jeff over at Elite Engineering is a good friend and we've both been selling our products to some of the same customers now for quite a while - as they compliment each other well.
There's no need to glue the carpet to the insulation, it's not glued in there now It just sits in place and is held in by seat bolts, or plastic panels, etc. The carpet simply installs back over it, no problem.
4 kits left of the 10 right now, but will have more late this week most likely. This is a great weekend mod that you definately won't regret doing, won't effect the resale value of your car unless you tell the buyer it's there (because you'd never know it was, other than it's quieter in the car than a car without it), and will only increase your driving comfort for sound and heat. With over 1000 kits sold to C5 owners (and, as stated before, a lot of them from the forum) I can sell this kit with solid confidence in it, and also because my cars are done with it Dodge wouldn't have used it in their Vipers if it didn't work!
Originally Posted by leimomi
What material did you use and where did you obtain it, please?
http://www.b-quiet.com/corvette.html
Be warned though, this was NOT precut and had to be bought in bulk. It cost me over 700 bucks without shipping and its a major PITA to install. If I had seen cowboy's option first I would have bought the tar based material and installed that underneath. Then bought this and installed it over the top for maximum sound deadening.
It would have saved me a ton of money and headache plus I was very satisfied with his partition so I can only assume it would be the same with this.
Cruise-In V Veteran
Thanks Dave, glad to hear you're happy with the partition also.
Originally Posted by Crazy Cowboy
Yes, as stated in the first post, it will dramatically reduce console heat and also reduce interior road noise too. If you've taken your car on a road trip (I have driven both my C6 coupe with every available option, and my 06 Z06 up to Bowling Green) you WILL notice the heat coming from the console and down by your leg. The car's are definately not hot like a C4 but there is room for improvement by far.
The full kit weighs under 6 lbs. Not currently offering half kits, only full kits for the C6 at this time.
I'll be interested when you have the vert section ready, or if you start selling cabin only. I installed the SS ceramic tunnel plate from Elite. I added (coated) headers & HF cats at the same time. I don't feel a change in the heat diffference at all. Could be the header/plate install offset each other temp wise, I dunno. But in any case, I'd be interested in anything that reduces the heat out put to the console area. But noise isn't an issue for me so I don't really care about the trunk area.
Cruise-In V Veteran
Originally Posted by Pozzo
How many square feet of material does the full kit contain?
#33
Cruise-In V Veteran
Originally Posted by Atomic Punk
hows it work?
#34
1 Post
I'd have to spend some time to figure all that out to be honest. Never really looked into it. I base the material used on how many kits can be made per bulk order of material. It covers all the area shown and also includes about 12 square feet of extra material with it.
Check your PM about request for shop manual info.
I did Dynapad in my coupe and the cargo area floor, along with the back of the passenger compartment behind the seats and covering under the console took 24 square feet ( two 32" x 54" sheets with no waste)
The Dynapad which is a thicker material that gives better sound deadening ran over $200.00 for the two sheets, so Dan's pricing with the thinner material, cut to fit is very inexpensive !!!!
I would think the cargo compartment sides and the floor would be at least another 24 square feet.
Estimate that about 50 square feet is required.
#36
Originally Posted by RBYCC
Dan
#37
1 Post
I measured the rear cargo compartment and it measured 39 inches long by 59 inches at the widest point. This works out to about 16 square feet. Why would 50 square feet be required?
If you reread my post, the area calculated would be for the cargo area floor, sides, and passenger compartment rear, console, sides and floor.
#38
Cruise-In V Veteran
Originally Posted by revo1059
Does it come with instructions on how to take the car apart and put it back together again?
