Silly Question
Old Jul 3, 2006 | 03:43 PM
tsgrayson's Avatar
tsgrayson
Default Silly Question
How are those exhaust plates held in place for the C6?
Old Jul 3, 2006 | 03:46 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
Exhaust plates? Do you mean the tunnel plate by chance?
Old Jul 3, 2006 | 03:47 PM
tsgrayson's Avatar
tsgrayson
Like these:
http://www.vetteshop.cc/default.asp?S=503&A=E&PKV=1032|0
Old Jul 3, 2006 | 04:03 PM
Vasta's Avatar
Vasta
Sorry, Can't help you with that one.
Old Jul 3, 2006 | 05:26 PM
TexJeep's Avatar
TexJeep
Check out the existing hanger bolts under the rear bumper. You loosen, NOT remove them and slip the exhaust enhancement plate under the bolts. Then re-tighten them. It's sort of a bitchy job because you don't have room, but it only takes about ten minutes and it's a good, solid install.
Old Jul 3, 2006 | 05:29 PM
Atomic Punk's Avatar
Atomic Punk
you can do it laying on the ground but it's a tight fit, (i did it this way,) but it would be easier to raise the rear end a little.
Old Jul 3, 2006 | 05:53 PM
johnodrake's Avatar
johnodrake
Moderator
Hey, A bubblehead on the board-- Awright!
To Silly Question
