clutch question
Old Jul 8, 2006 | 12:15 PM
tampacarlover's Avatar
tampacarlover
Default clutch question
I have a question about clutch take-up. When you are in stop and go traffic, for instance, and you slowly let up on the clutch without touching the gas, does your car shudder until the clutch is fully engaged, or move smoothly?
Old Jul 8, 2006 | 01:04 PM
DP Dave's Avatar
DP Dave
19,000 miles on my 05 Z51 and it is as smooth as silk.
Old Jul 8, 2006 | 01:14 PM
2BBVette's Avatar
2BBVette
That only happens a little to me if I'm in 2nd gear.
Old Jul 8, 2006 | 01:24 PM
Pozzo's Avatar
Pozzo
If I let up on the clutch without giving it gas the car will shudder and then stall. You have to use the gas pedal.
Old Jul 8, 2006 | 01:29 PM
TrackNoob's Avatar
TrackNoob
Then I would get that looked at.
My 2006 does not shudder (the OPs question) and certainly does not stall when the clutch is released on level ground (or even slight uphill, such as a flyover) and NO throttle is given. The engine management system and e-throttle simply keeps the RPMs right at 600, and it motors along nicely.
Old Jul 8, 2006 | 02:31 PM
Maybesomeday312's Avatar
Maybesomeday312
Mine will stall if not given throttle when letting up on the clutch...I've never driven a manual that doesn't stall when not getting on the throttle when letting the clutch out.
Old Jul 8, 2006 | 02:35 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Gets mo betta with mileage. I noticed a significant difference by 5K. But no gas? even at 23k it shudders
Old Jul 8, 2006 | 03:28 PM
TrackNoob's Avatar
TrackNoob
Sorry, guys, I misunderstood the original poster slightly. He said fully released in stop and go traffic, so let me be clear about what I was thinking:
1) I have never tried to start out from a standing stop with NO gas and feathering the clutch. I imagine it might well either shudder and/or stall, as people have offered.
2) What I mean is that I spend at least 20 minutes of my two hour road trip every day in stop-n-go traffic, and in that stop-n-go traffic, I often have to slow down, speed up, slow down, all the way to a snails pace and that as long as I am moving, there is no need to give any gas at all, and no shudder either, with clutch fully out, even at walking speed, and even while climbing the flyover ramp as well.
Of course, when I do need to operate the clutch, yes, I give it a bit of gas, but never get any sort of shudder whatsoever. Sorry for any misunderstanding/misstatement, hope that clears it up.
(Of course, with our low end torque, you know what I am going to do the very next time I am in the car and it is at operating temp: I am going to try to finesse the clutch to see if I can indeed get it to start out without a stall or shudder - not that I would do that test repeatedly...)
Old Jul 8, 2006 | 03:36 PM
2LT-Z51's Avatar
2LT-Z51
smoothly - no throttle
yes the engine will keep it at idle speed...
you can get up to speed by shifting through the gears and no throttle... try it it is really great how much power and brains this car has....
Old Jul 8, 2006 | 05:19 PM
beaversstonehaven's Avatar
beaversstonehaven
Mine does shudder when I use the above method when starting out. Both in 1st gear and reverse. 7,000 miles on the car and it has done that since new.
Old Jul 8, 2006 | 05:25 PM
tampacarlover
OK. This is exactly what I was talking about. I wasn't sure if there was something wrong with mine or not, and wanted to see if others had the same experience.
Old Jul 8, 2006 | 05:32 PM
prs62's Avatar
prs62
St. Jude Donor '05-'07
When I took delivery the salesman was going over all the features of the C6. He said to let the clutch out slowly, no gas and the car would start moving smoothly. That's exactly what it did from day 1 and still does now 10,000 miles later. I love this car.
Old Jul 8, 2006 | 05:34 PM
Dale_K's Avatar
Dale_K
Mine shudders trying to go 1 mph (or less) such as easing into my garage. The car will move without stalling by easing out the clutch at idle speed but it shudders. It doesn't seem to shudder in everyday driving although the engagement is kind of touchy. Pretty nearly every car and truck I've ever driven was better than the C6 at having a predictable and easy to modulate engagement point. For example it would be hard to hold the C6 stationary on a small incline using the clutch, not that I would ever do that anyway. The over-center spring probably plays a role in this.
Old Jul 8, 2006 | 06:06 PM
C6SNOOPY's Avatar
C6SNOOPY
Mine will shudder also slightly. Need to give it slight throttle. 5K miles and has done it since new. 1st and reverse.
Glad to hear I am not the only one who is experiencing this!!!!!!!!1
Old Jul 8, 2006 | 08:04 PM
exukboy's Avatar
exukboy
Same here.
Old Jul 8, 2006 | 10:38 PM
eagles6998's Avatar
eagles6998
Mine seems ok at 1200 miles!!!!!
To clutch question
