Buzzing Noise
Old Jul 10, 2006 | 10:07 AM
VicRed-STL's Avatar
VicRed-STL
Default Buzzing Noise
My 2005-MN6 is making a buzzing sound which seems to come from behind the instrument panel although I suppose it could be coming from the engine. It happens in second or third gear as I approach 3,000 RPM and continues until I back the RPM off. I have never heard the sound when driving in any other gear. I only use premium gasoline in my car. To make matters worse, sometimes it will not make the noise at all. Sunday morning, I drove about a mile to the store without any buzzing sound. But, on the drive home it was there. Does anyone have any idea what this could be? I would prefer to have a better idea of what this is before asking the dealer to search for it. Thanks in advance.
Old Jul 10, 2006 | 10:41 AM
greta's Avatar
greta
Gosh, can't help you there. But your'e right when you say you want to have a better idea before going to the dealer otherwise you'll get their stuipid patenet answer "could not duplicate" .....or "no problem foiund" !!!
Old Jul 10, 2006 | 11:00 AM
BlackOps's Avatar
BlackOps
From: Evansville, IN The GOCC, rebels without a clue.
St. Jude Donor '06
Try putting your hand on the shifter to see if that dampens the noise. My shifter rattles, or buzzes, slightly as I accelerate, but it's not bad enough to bother me right now.
Don
Old Jul 10, 2006 | 12:57 PM
greta's Avatar
greta
Don
Ditto....
Old Jul 10, 2006 | 01:48 PM
CessnaDriver's Avatar
CessnaDriver
The rattle can be tamed with felt stickys from Home Depot.
Old Jul 11, 2006 | 01:59 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
Check the trim around the HUD also.
Old Jul 23, 2006 | 05:31 AM
avpentinc's Avatar
avpentinc
just to clarify, i had a noise come from what it seemed like behine the heat/hvac vents. Sometimes it would buzz, other times it was quiet. I brought it in to the dealer and they fixed it. It was a loose screw. hopefully this helps. good luck
Old Jul 23, 2006 | 11:15 PM
usmarine2003's Avatar
usmarine2003
I too hear a buzzing sound from my 2005 C6. Almost as if the speedometer cable is ratteling?
Old Jul 23, 2006 | 11:21 PM
cthusker's Avatar
cthusker
I don't believe there is a cable as such on these cars? It's all electronic now but I could be wrong. I'm sure someone will answer this one....
Old Jul 23, 2006 | 11:50 PM
DrivnXcitment's Avatar
DrivnXcitment
You're right Husker. These are drive by wire cars. The throttle body does not have a cable on it. It's an electric signal sent from the pedal to the ECM to the throttle body and back again to the speedometer and instrument cluster.
Old Oct 1, 2023 | 05:40 PM
LinLu's Avatar
LinLu
6th Gear
Default Rattle Noise C6 Corvette Instrument Panel
I wonder what's wrong
Old Oct 1, 2023 | 05:51 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
If it is gear and RPM specific this is probably not it but, to be sure, the lower windshield trim piece sometimes buzzes with speed/wind. To eliminate as a potential source, put a piece of black electrical tape on the edge and tape it to the glass.
Good luck.
Old Oct 2, 2023 | 10:17 AM
Chatman's Avatar
Chatman
Use a stethoscope to locate the sound if touching one thing after another doesn't work.
Old Oct 2, 2023 | 10:32 AM
87SAM's Avatar
87SAM
I’m pretty sure the buzz is gone by now
Old Oct 2, 2023 | 11:16 AM
PDsVettes's Avatar
PDsVettes
It's only been 17 years since the problem started. I'd give it a couple of more years to be sure.
To Buzzing Noise
