Tire Experts come inside!
Old Jul 13, 2006 | 09:49 PM
glennhl's Avatar
glennhl
Default Tire Experts come inside!
Is this patch acceptable. The tires is a GY F1 Supercar 285/35-19 and has over 90% of its tread left.
Old Jul 13, 2006 | 10:23 PM
2LT-Z51's Avatar
2LT-Z51
WOW.... who did the patch??
it looks really high on the sidewall.....
i would think goodyear would just replace it....
hope someone here is a goodyear rep..... ttt
Old Jul 13, 2006 | 10:29 PM
PAVette's Avatar
PAVette
Originally Posted by 2LT-Z51
WOW....it looks really high on the sidewall.....
Old Jul 13, 2006 | 10:34 PM
Vette_DD's Avatar
Vette_DD
GoodYear replaced one of my tires FREE when a plug was too close to the sidewall to hold. Check your GoodYear pamphlet that came with the car. Take it with you to a GoodYear-certified dealer if/when that patch doesn't hold. Road hazard warranty is good for the first 2/32" of tread or 12 months, whichever comes first.
Old Jul 13, 2006 | 10:36 PM
jim213's Avatar
jim213
I would not trust that repair. Talk to them about a new tire.
Old Jul 13, 2006 | 10:44 PM
Tire Guy's Avatar
Tire Guy
St. Jude Donor '08
It is hard to tell from the picture how close it it to the curvature of the outside tread/shoulder. I will venture a guess that it will probably be OK because of the structure of these types of tires. They are very flat right out to the sidewall with very little curvature. If it was a higher series tire, like a 70 or 75 aspect ratio it would definitley be a problem. As the tire flexes it rolls the patch loose. There is very little flex in the EMTs. If you do lose air again, don't let them try again or worse yet, plug it, just replace it.
The Tire Guy
Old Jul 13, 2006 | 10:52 PM
rickbrick's Avatar
rickbrick
St. Jude Donor '06
IMO The tire is now a big question mark because of the patch. The patch appears to be very close to the sidewall. Do you really want that question mark in your head whan you are driving your AWESOME Corvette? I wouldn't!
Old Jul 13, 2006 | 10:55 PM
Tire Guy's Avatar
Tire Guy
St. Jude Donor '08
Can you shoot the other side to see where the hole is in the tread? It makes a difference...
The Tire Guy
Old Jul 13, 2006 | 11:35 PM
glennhl's Avatar
glennhl
The Tire Guy
I can not find a mark on the other side, but here is the area:
Feeling the patch, this is my best estimate of where the center of the patch is located:
Old Jul 13, 2006 | 11:40 PM
99FewteRC5's Avatar
99FewteRC5
Thats too close to the side wall (IMO) but it'll probably hold up ok. (for daily driving). I would try and get goodyear to replace it.
Old Jul 14, 2006 | 12:01 AM
cthusker's Avatar
cthusker
I wouldn't want it on my car but it will probably hold. If you have good tread on your other tire then now is the time to replace this one!
Old Jul 14, 2006 | 12:33 AM
Steve Germany's Avatar
Steve Germany
Usually it has to be in the belt area to be repairable. That repair is way past the optimal location for a good repair.
Old Jul 14, 2006 | 01:30 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Too questionable in my opinion...and I don't want anything questionable on my Corvette.
Old Jul 14, 2006 | 02:28 AM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
NOT acceptable...too close to the sidewall!!
Old Jul 14, 2006 | 02:33 AM
antoniopaolo's Avatar
antoniopaolo
No tire expert here but from my undersstanding of how these are designed that fix is too close. Probably be okay but I would ask Goodyear some more questions re: replacement.
Best of luck.
Old Jul 14, 2006 | 07:01 AM
Tire Guy's Avatar
Tire Guy
St. Jude Donor '08
Too close to tell. It is 50-50 that it will hold. If you can get a free replacement then that would be the best way to go.
The Tire Guy
Old Jul 14, 2006 | 07:32 AM
lagogarda's Avatar
lagogarda
St. Jude Donor 06
To Tire Experts come inside!
Old Jul 14, 2006 | 08:17 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Too high on the sidewall. Get another tire.
Old Jul 14, 2006 | 09:54 AM
PO10TIAL's Avatar
PO10TIAL
Old Jul 14, 2006 | 10:41 AM
glennhl's Avatar
glennhl
Thanks for all the advice, you guys all confirmed the way I felt. I'll see what Goodyear says.
Thanks,
Glenn
